Question about Sharp EL-531VB Calculator
The digits are not displaying properly
When i turn on the calculator, a part of the zero "0" is not shown. if i perform a function the digit at the extreme right of the screen is not displayed in full
  • Anonymous Dec 14, 2008
    I'm the same. I tried chnging the batteries but no luck in getting the digits to show right.
  • Anonymous Jan 08, 2009
    I have similar problem--an LCD screen, typing 888 yields E88. Computer was not dropped or handled rough, and calculator is pure solar, no batteries.
  • Sharp Master
  • 7,993 Answers
Increase the number of digits displayed. In floating mode the calculator can displyay up to nine decimal digits. And no matter what that last digit maybe, you can safely ignore it. More often than not the extra digits are zeros. As to the value of PI not displaying the 7th or 8th digit, do not worry: most calculations with Pi are precise enough if you use 3.14.
Hope it helps.
Posted on Sep 20, 2009
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
My HP-12C calculator shows 0.000000, how do I clear this display?
Press "f" then the digit representing the number of digits you want after the decimal point.
Aug 22, 2012 | HP 12c Calculator
Radians in texas calculator
Press [2nd][.] (FORMAT). Press the DownArrow (INS). You will se the angle unit displayed as DEG. Press [2nd][ENTER] to set angle unit to RAD. You will see RAD displayed. Press [2nd][CP] to (QUIT).
Keep in mind that this is a financial calculator and that the number of decimal digits is by default set to 2.
If you use it to calculate values of some scientific functions you must keep more digits. To change the number of digits in display, press as before [2nd][.] (FORMAT]. The display will show DEC= and the current number of decimal digits. Key in a value between (0, and 9) and press ENTER. Press [2nd][CPT] to (Quit).
Jun 23, 2012 | Texas Instruments BA-II Plus Calculator
I am having trouble figuring out how to enter problems to find logarithmic functions
Let me give you a general recipe to familiarize yourself with any calculator, if you are averse to reading the manuals.
Most function will work in one of two ways.
1st way
Enter the number, then press the key,; the result is displayed.immediately.
Second way
Press the function key ( a left parenthesis may be displayed) enter the number (close the right parenthesis if there was a left one) press the = or EXE or ENTER keys.
Try the two ways described above to calculate the following values. The answers are given. Here log is he decimal logarithm and ln is the natural logarithm.
log(1)=0
ln(1)=0
ln(2)=0.693147181
log(2)=0.301029996
ln(100)=4.605170186
log(10)=1 (= number of zeros after the 1)
log(100)=2. (= number of zeros after the 1)
log(1000)=3 (number of zeros after the 1)
log(10000)=4 (number of zeros after the 1)
Aug 17, 2011 | Texas Instruments TI-30 XIIS Calculator
When I type sin(6pi) in my calculator I get: 2x10^ -13 But sin(6pi) is normally 0. The calculator gives the right answer when in degrees: sin(3x360) = 0 How to fix this ?
The sine of 6pi is indeed zero. The calculator works with twelve decimal digits while pi is an irrational number with an infinite number of decimal digits. Thus the calculator cannot actually calculate the sine of 6pi, instead it calculates the sine of 18.8495559215. The sine of that number is close to zero but not quite, about 0.000000000002 which is what the calculator shows. This is a natural consequence of using finite machines to deal with infinite numbers.
In degrees, 3*360 is 1080 exactly and thus the calculator can produce an answer of exactly zero.
You'll notice that the calculator also gives a nonzero result for the sine of 4pi.
The "proper" fix for this is something called "argument reduction." If the argument lies outside the range of 0 to 2pi (or alternatively, the range -pi to pi), add or subtract multiples of 2pi until the argument is inside the range. So in this case, subtract 6pi from 6pi to get zero, then take the sine of that.
Bear in mind that argument reduction won't always work, since it too is limited to twelve-digit arithmetic.
Dec 12, 2010 | Texas Instruments TI-84 Plus Calculator
Can this convert decimal measurements to fractions of an inch
Enters a proper or improper fraction,
b?c (b { 6 digits, c { 3 digits). When
possible, improper fractions are
displayed as mixed numbers.
3 F 4 3?4
8 3 J 21?4
Single-variable functions display
decimal results.
1 F 2 0 0.25
a F b F c Enters the mixed fraction a b?c.
(a, b, c { 3 digits each, with the total
digits { 8).
6 F 4 F 6 64?6
J 62?3
"s Toggles display between a mixed
number and an improper fraction.
30 F 4 30?4
"s 71?2
"s 15?2
"s 71?2
"y Toggles display between fraction and
decimal.
55 F 24 55?24
"y 2.291666667
"y 27?24
If a result would overflow or if fixed decimal is 0, no
fraction to decimal conversion occurs. It is not an error.
Denominator must be a whole number {999.
Nov 28, 2010 | Texas Instruments TI-30XA Calculator
How to change date and time on a sharp EL - 1197P calculator
Found Instructions for EL-1197PIII Calculator, think its the same thing
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position. Date: · Enter in the order of month, day and year, then press to complete the entry. · Use to separate month, day, and year. · When is pressed, the number entered is evaluated and displayed as “date” if the value is within the following range; “Error” is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: · Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) · If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”. · Use to separate hour and minute values. · When is pressed, the number entered is evaluated and displayed as “time” if the value is within the following range; “Error” is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Apr 06, 2010 | Sharp EL-1197P Calculator
I want to make more than five zero at my calculater
Result display FIX
To change the number of decimal digits, press LEFT SHIFT (Blue) key then press (. In doing so you are setting your result display to FIX. Specify the number of digits you want by pressing 0, 1,2,3.., or 9
Result display ENGineering
Press LEFT SHIFT (Blue) key, then press ) key. Specify the number of decimal digits in the mantissa by pressing one of the number keys.
Result display SCIentific
Press RIGHT SHIFT (orange) key followed by (
press one of the digit keys (0,1,2,...,7,8,9) to specify the number of digits.
Mar 31, 2010 | HP 20s Calculator
My TI-83 Plus Calculator automatically round off my answers. How do I turn it off.
Press [MODE]. Use arrow down to go to second line Float. Use left arrow key to move cursor to a number other than zero and press [ENTER]. If you highlight 2 your results will have 2 decimal digits, but if 0 is highlighted all results will be integers (no decimals).
Hope it helps.
Nov 18, 2009 | Texas Instruments TI-83 Plus Calculator
How do i use scientific notation
Press [SHIFT][MODE][7:Sci]. Select the number of digits in the number.
In the exemples below, the Zeros are place holders.
0: 10 digits 0.000000000x10^0
1: 1 digit 0[x]10^0
2: 2 digits 0.0x10^0
9: 9 digits 0.00000000x10^0
Hope it helps
Sep 26, 2009 | Casio FX-115ES Scientific Calculator
Sharp EL-531VB Calculator Logo
222 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
