Question about Refrigerators
Recently bought a whirlpool bottom freezer, year we think is 1985. Need pictures on where drawers go and how they go. Model number is EB19MKILWRO or 19ABR85. Please advise.
zeusfaber
  • 247 Answers
SOURCE: fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
Posted on May 16, 2007
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
SOURCE: water in bottom of fridge
Thanks to all who spent money or shared their experience to have somebody do this repair, and I really mean it.
I have a Whirlpool TopLoad Fridge (not a side by side).
Things you'll need
30 minutes
Small socket for cardboard panel on lower back and panel inside freezer
Bicycle Pump
4 Towels
Hair Dryer
1. Take everything out of freezer
2. Turn dials off in fridge for both compartments
3. Pull fridge out so you can get behind it and unplug it
4. Be vigilant of ice maker line if installed
5. Pull cardboard panel off on back
On the left side you should see the back of the skinny drip pan and a small line. That line goes from the freezer and is most likely clogged.
6. Blow dry the back of the freezer enough so the ice is thawed at the bottom of the back panel.
7. Remove the two screws on the back panel. You may just be able to pull it toward you enough to get behind it. You'll see the coils and fan, and underneath these you may see some ice sheets and there should be a hole. That is the drain line that is clogged. I heated up some water and poured it over the drain to thaw the line. You may want to remove the crisper drawers and put some towels down there to catch the overflow. Once the ice is thawed enough at the drain. Go to the back of the fridge and place the end of the bicycle pump at the bottom of the drain hose. Apply pressure to get a good seal but keep pumping. You may have to go back and forth between pumping and thawing, but you'll know it is clear when you hear air going into the freezer and then the wonderful moment when water drips into the drip pan as advertised!
Keep those fridges less full so that the door stays sealed and keep the seal clean and also keep your doors from having too much stuff so the weight of the door doesn't pull away.
Okay, put it back together, turn everything on and be careful of your cord and lines when pushing the fridge back. Thank the Lord ours has wheels and man,was it cruddy underneath. Vacuum those coils underneath the fridge too for proper air circulation.
Blessings to you!
tay
Posted on Jan 11, 2009
peyton32034
  • 410 Answers
SOURCE: Superba fridge 1992 occasonal water under bottom freezer drawer
you have a frozen defrost drain. in order to fix this you will need to remove all shelves and basket out of the freezer. then remove rear evap cover. one youve gained access to this area you will see at the bottom of the coil an aluminum pan that most likely wil be iced over. clear away this ice then try to flush out the drain line with warm water. sometimes its neccessary to force water into drain line with a large syringe or turkey baster. this should fix ya up.
good luck and thx for using fixya Peyton
Posted on Jan 28, 2009
  • 19 Answers
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
could be an air leak around the door seals. put a piece of paper between the door and the freezer if it slides around easly then the seal is leaking air and moisture into the freezer. Also -20 is extream. you could turn the temp up by 10 or 15 degrees and it may solve the problem and so money!
Posted on Jul 26, 2009
LG French door bottom freezer unit is only 5 years old. Bottom freezer suddenly not keeping food frozen. Ice cubes are melting, ice cream is soft, and there is water on bags of frozen food in top basket...
You have a defrost condensate drain blockage where all the water from defrost remains inside the freezer compartment and causes the symptons you are having. I cannot tell you how to remove every model numbers freezer rear panel but I think that if you study over my link here=> Leaking Refrigerators and this link HERE you will get an idea of what to do. I am here to answer any questions, Sea Breeze
Aug 09, 2013 | Refrigerators
Bought house,but didn't come with instructions for the stove.
absolutely but you will need to tell us which model and serial number you have
most models it can be found ion the drawer compartment
it might be on the back of the drawer front
Oct 28, 2009 | Ovens
Bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Jul 26, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
|Need to identify model to order spare parts
MG,
Check inside the freezer compartment. Pull the drawers out... there's a sticker in there with the model number on it but it's wayyyyy hidden.
SG
May 23, 2009 | Whirlpool Refrigerators
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
Whirlpool refrigerator stop cold but frosting bad
Hello Catherine Fu,
Welcome
You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
Help!! It is an very expensive refrigerator and ONLY 4 years old .
First,I think you need to have a new tech.
It sounds like you have either an air leak allowing out side air in and this causes the icing.
Or you may need some freon (coolant gas) .
If your freon pressure is low it can ice up.
Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
You need to call a different tech and let him see what's happening.
Some company that is reliable!
Let me know what they do for you.
God bless, Huuum
please remember to leave a rating.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
