Question about Adaptec 1 Bay ACS-100 (2177400) USB 2.0 External Drive Case
Getting recorded data from my Hard Drive asking to be formatted!
I have a 3.5 mobile adaptec hardrive which has data on it. Recently, my computer had to be restored to original brand new condition so I also had to re-install all my other programs and hardware such as Adaptec. Although my Adaptec Hardrive was not connected during the recovery process of my Sony Vaio PGFrv26 with Home XP,(don't know if that is x64 or x86) it will not open at all now as it is asking to format it! I tried to open it without formatting in another Sony, different model with Windows XP Professional...same thing. Then I tried to open it with an Asus computer with Windows XP....same thing...it is asking to be formatted! Help...how can I get my data from it now?
  • 734 Answers
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
MY PC WINDOWS XP ASKS TO FORMAT MY STOREJET 25 320 GB TRANSCEND PORTABLE HARD DRIVE
If it's asking to be formatted you need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Transcend StoreJet 25 Mobile - Hard drive...
How do I delete all the info backed up on my irocks external hard drive?
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Jan 14, 2011 | i-rocks External Hard Drive Enclosure -...
I am trying to install a seagate hardrive with no installation info do i need a disk or can i get info on line
if its a secondary drive you can just put it in your computer and it will ask you to format it and you can go right ahead and do it if your installing an os it will format anyways and you shouldnt need any addtional drivers it should have the drivers and data already on it.
Oct 21, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
1tb WD external hardrive not mounting, can't access my info ?
First of all, restoring a hard drive rarely affects data stored on it. I usually just adjusts the supporting software that allows it to run properly. Definately check the manual prior to restoring it, though. Formatting it will absolutely erase everything (unless your the FBI). I'm about 99% sure that restoring it will leave your stored data completely unaffected.
You're better off performing the work using the newest OS available. BTW, your BF can plug into the internet and get upgraded to 10.4.11 as well for free and it doesn't take long.
Oct 06, 2009 | Western Digital My Book Essential 1TB...
My segate 300Gb HDD keeps asking to format it when i recently pluged it into a new computer to transfer data to and it said that the driver didnt install correctly. since then it keeps asking to forma
I'm assuming that this was functioning at one point. If you are using Windows, Right click on my computer and click "Manage" Then go to disk management? Does it see the drive at all. If so, has a letter been assigned? It is possible that the operating system will show the drive even if it can't read the data. Look to see what file system and how it sees the disk having been partitioned. It is possible that your partition table has been corrupted. This can possibly be fixed using a tool like disk doctor or fdisk.
If, on the other hand, the drive is also making funny noises, you may have a mechanical failure on the drive.
May 29, 2009 | Seagate 300GB USB 2.0/FireWire Hard Drive...
Formatting my WD external hardrive
Hi, In computer terms, formatting a hardrive is the process of preparing/setting the different areas (for read/write) of the harddrive and keeping a list of the addresses. This way the computer would know what data went with what and to where in the HD. Most if not all new HDs are not formatted (prepared) for computer use but are detectable by the PC. Formatting not only makes the HD recognizable, it is now usable. By formatting, the PC also erases any and all references to the existing data on the HD. After being erased and prepared, it also checked for any possible errors. Hope this be of some idea/help. Good luck and kind regards.
Sep 10, 2007 | Western Digital My Book Essential Edition...
Seagate external hardrive
Try to plug it into more than 1 computer other than your PC. If it works, then the problem is the interface between the hard drive and your computer and if it really doesn't work, you're solution is have it recover by data recovery experts. Here are a few things you need to keep in mind, on taking your first steps in such a situation: Do not open the hard disk and try to repair it on your own. If you're data is really, very valuable, don't use automatic data recovery tools. Before you bring it, wrap the defective units in anti-static envelope if possible, bubble wrap it, and seal package securely. You also had an option to recover it on your own by using known data recovery software but it's risky compared if you bring it to a data recovery experts. If the problem is within the mechanical parts of a hard drive, there's a possibility that you will not attain a 98% chance of recovery if you do it on your own.
Mar 20, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Adaptec 1 Bay ACS-100 (2177400) USB 2.0 External Drive Case Logo
204 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Timothy Van Der...
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
