Question about Canon PowerShot A530 Digital Camera
I have a powershot a530 and i am trying to replace the front cover, but i am having a problem taking off the entire cover from the camera. I have all the visible screws taken out, but the cover won't release. and i don't want to force it... any help?
  • hitower1972 May 11, 2010
    i have a canon powershot a530 and it wont turn on any ideas
I had a similair problem while removing the rear cover. As I am not sure if your problem refers to the front cover only, I will describe how I managed to pull of the rear part.
Be sure to pull out all the screws (including the one inside the battery compartment) - there are 7 screws altogether. It is also necessary to keep the battery compartment lid open. It needs some strength to remove the rear cover. I suggest that you insert a screwdriver in the crack between both covers at the bottom or side of the camera and while twisting it sligthly, work all the way around the camera.
Good luck
Posted on Dec 18, 2008
I try to take photos with Canon powershot A530 but it keeps saying memory card locked. What do I do and what does that mean?
Umm, take out the memory card from the camera and there should be this small lever at the side of the card that shifts up and down. Shift it out of the "locked" mode.
Jul 10, 2010 | Canon PowerShot A530 Digital Camera
Setting date with each use of camera
n your battery compartiment is a small cover labeled CR1220.
PLEASE READ MANUAL on how to open it.
Behind that cover you will find a coin shaped battery, provably type CR1220.
PLEASE READ MANUAL on how to remove it.
Get a replacement battery (watch store/ camera store/...)
PLEASE READ MANUAL on how to install it.
Power on camera, set date and time and DONE!
Sep 12, 2009 | Canon PowerShot A530 Digital Camera
My canon powershot A530 WONT TURN ON!!!!
Check the batteries, and if they are bad, replace them. If it has rechargable batteries, just get rid of them and try regular alkaline batteries. That should be the fix.
Oct 05, 2008 | Canon PowerShot A530 Digital Camera
Taking apart a A530
Leave the mode selector wheel alone. It is not necessary to remove it. Take a look at the following A530 disassembly guide. It should be of help:
Apr 24, 2008 | Canon PowerShot A530 Digital Camera
No power
Hi , some connection overheating disconnect solder need fixya recommended repair shop near just enter your zip code you will find service near you.
Jan 25, 2008 | Canon PowerShot A530 Digital Camera
Zoom won't work
I have had the exact same problem develop with the A530- now twice!
The first time I had to send it back to Canon to fix it. According to the repair summary, what they replaced was, well, the entire control board...not many things breaking can cause the entire zoom/buttons to stop functioning aside from a control board malfunction of some sort.
Anyways, Canon fixed the camera, everything was hunky dory.
For six months. Then the problem developed again. When the same problem occurs twice in a row without any warning whatsoever, that's when I start getting annoyed and consider buying another camera.
So at least in my case, the solution to the problem was that it had to go back to Canon for repairs. I had an extended warranty on my camera, so I can't say how much it will cost to repair the problem. If it happens again like it did in my case...consider buying another camera.
Oct 10, 2007 | Canon PowerShot A530 Digital Camera
My flash won't work!!!
Check to make sure your camera's not on the A530 recall advisory list. Maybe the flash capacitor isn't getting enough power due to the shorting described in the advisory?:
Sep 28, 2007 | Canon PowerShot A530 Digital Camera
Canon a530 powershot won't snap a picture
sounds like the flash isn't charging, as the flash icon flashes while the flash is charging before letting you take the photo. Put it in "P" and disable the flash and see if it'll let you take a photo. G>
Sep 03, 2007 | Canon PowerShot A530 Digital Camera
Canon PowerShot A530 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
