Question about Dryers
Loud squeaking when you turn dryer on
Sounds like it needs oil but don't know which part needs it or replaced
  • 36 Answers
Take it apart and oil evey thing also spinning parts by hand can help you find the bad part look closely at the belt pulley for ware
Posted on Dec 09, 2008
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Feb 16, 2013 | Dryers
Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric Dryer......Starts, runs and drys but has a REALLY loud squeaking sound
Your drum rollers is in need of lubrication.
You can lube them with a high quality machine oil like 3inOne oil.
Please rate me
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
Loud squeaking noise
it sounds like your roller bearings are bad you need to get the top open then take the front off loosen the belt take out the tumbler try to squirt oil on the shaft the rollers are on there should be two of them,put it back together and try it,if that doesn't work replace them.
Dec 21, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer has a loud squeaking noise when you first start it up
Sounds like your drum rollers need lubrication or replacement.
If you have a front load machine, remove the front of the machine, this will expose the drum. Remove the drum and this will expose the drum rollers. Lubricate the drum rollers with a good grade of machine oil like 3 in One oil at the shaft.
Hope this helps
Oct 01, 2009 | Hotpoint Dryers
Squeaky GE Dryer
Greetings,
sight unseen, its hard to say exactly, but it is a place to start by looking at the belt pulley. these will make squeaking sound when bad or going bad..The drum rollers usually make a thumping sound, however, they can squeak too before failing..I would try and add a few drops of turbine oil to see if either get quiet..if so, replace when find which one is causing noise..Bruce
PS
its possible, the motor itself could cause this, but slim
Jul 26, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer turns and heats, but makes a very loud squeaking (or should I say, SCREECHING) noise. The heavier the load, the louder the squeaking.
Does it sound like a belt ?
Or does it sound like metal ?
Might need to replace the drive belt..
Or - it could be the bearings..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
Jun 17, 2009 | Magic Chef CYG4000AWW Gas Dryer
Dryer making loud squeaking sound
Try checking the glide wheels under the barrel they may need to be cleaned and lubed.
Mar 11, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Loud Squeaking Noise kenmore gas dryer 80 series
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Dec 07, 2007 | Kenmore 63942 Dryer
Dryers Logo
80 people viewed this question
Top Dryers Experts
