Question about Sony DVP-NS775V DVD Player
I have the same problem as the others. My DVD Player does not play DVD's any longer. I believe it is the laser pickup. In the old days, you could find a diagram of your unit and order a replacement part (in this case, the laser pickup) but nowadays, only authorized Sony Service Centers seem to have access to the information. If you can identify the part, it's easy to order replacements from this website: The problem is getting access to the information. If you tell a authorized Sony Service Center that you want to buy a new laser pickup for your DVD player, they won't look it up for you. So the industry is protecting itself. Does anyone know how to get access to the list of replacement parts (repleacement level, like the laser pickup assembly for instance--not resistors and diodes) for DVD players, specifically for Sony DVD players?
4 Suggested Answers
SOURCE: Sony DVP-NS57P all region
try thomson
Posted on Feb 04, 2008
  • 54 Answers
SOURCE: SONY DVP-S7000 does not play DVD
All reviews that I am reading confirm my belief. It is a 1st generation DVD player and therefore will be hard pressed to play any newer DVDs. Think of it as technology advancing. It's sad but it happens. Even newer DVD players can not play the types of movies being developed today. i.e. BluRay discs. So if you cleaned it and you can play picture discs chances are you're going to have to sacrifice which movies you can watch and search for those it will play.
Posted on Jan 14, 2009
SOURCE: Sony DVD player DVP-NS30 does not play dvds
Change the motor disc spindle,good luck
Posted on Jun 07, 2009
  • 734 Answers
SOURCE: Sony portable DVD player dvp-fx970 won't play dvd
Use lens cleaner TDK or wash dvd disks with hot tap water then block off the water drops.
Posted on Feb 09, 2012
0 characters
1 Points
My sony dvp-fx820 will play cds fine , but not dvds thought it would be the laser pickup but,,, does anyone know ? before i wast my money what else it may be? thanks TB
You are correct. The Optical Pickup(laser) is most likely worn out. I'm going to take a stab at it and say you most likely play DVDs most of the time. The pickup actually has two lasers in one casing, a DVD and CD(the two use a different wavelength light, which is why you need two lasers). Which ever type of disc you play the most, that laser will wear out the fastest. All said, you will most likely need a new pickup.
Dec 19, 2014 | Sony DVP-FX820 DVD Player
My Sony DVP-CX995V quit playing DVD's. I was listening to a CD, stoped it, went to menu, picked a DVD and bow it say's " Cannot Read Disc " On ALL of My DVD's. All CD's & DVD's are storebought. I've had...
does the spindle motor even try and spin the disk? Pop the top (8 screws) and watch the loader grab a disk and place into transport. The disc should immediantly start to spin and the little laser should scoot back and forth looking for something. If the disc never spins but the laser is moving, you may have a bad motor, or a bad pickup (transport mechanism includes motor and laser pickup). A replacement for this model is about $125 but you can get the same part out of a cheap DVP-S360 for about $20 on ebay. Just make sure you ask if it works before you buy it on BOTH CD and DVD as its 2 different lasers in that part.
Sep 09, 2013 | Sony DVP-CX850D DVD Player
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
No matter what DVD I load in the player, it won't play the DVD. It says "Cannot play this disk". What's the problem?
The first thing to try is to clean the laser itself by using a cleaning disc. If that fails then most likely the pickup laser is no longer any good. This is usually obvious if you place an audio CD in the unit and it plays fine : )
Jul 27, 2011 | Sony DVP-FX750 Portable DVD Player
Loading is blinking
Try using a cleaning disk for the laser eye. This is a special dvd with a brush grafted on it to clean off thedoirt on the laser. Hired DVD;s are often covered in greasy finger marks and other debris which gets transferred to the iris as the disk spins. this eventually clogs the laser and it can no longer do a load and often reports no disk.
Please rate my help++++Thankls for using FIXYA
Jun 16, 2010 | Sony DVP-NS575P DVD Player
My sony DVP-NS725P will not play discs
Run a DVD disc cleaner through it and see if that helps. If not then open it up and manually clean the laser pickup lens. Then give it a go. If that didn't help, then open it back up and replace the optical drive.
Feb 18, 2010 | Sony DVP-NS725P DVD Player
What do I do when my sony dvd player stops playing cds. It plays the dvd's normally, but will not read cds. It is a Sony DAV-BC150 multidisc player.
that is very unusual the laser pickup has failed in the CD side of it usually it is the other way around but anyway you need to have it replaced about a 60 dollar job
Dec 02, 2009 | Sony DVP-NS315 DVD Player
My dvd player will play CD's but not DVD's is it worth fixing? I have a Sony CX995V wonderful machine
Manufacturer Sony Part Number A-6061-908-A Description KHM-290AAA, OPTICAL UNIT
Sep 27, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Skips or won't play disc if even slightly scratched
Hello opie440,
The optics might be dirty or the pickup assembly might need alignment. In the former case you can get an optics cleaning kit and try to clean the laser LED and pickup assembly. For the latter cause you will need to have thre unit aligned at a TV repair shop.
Feb 18, 2008 | Sony DVP-S530D DVD Player
Sony DVP-NS775V DVD Player Logo
Top Sony DVD & Blu-Ray Players Experts
Mando Mojica
Mando Mojica
Are you a Sony DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
