Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Physical damage to lcd screen
If there is physical damage to the screen , is it very expensive to replace ?
I have TCL LCD TV 32E61
Dispaly problem in Centre White line
Posted on Dec 29, 2008
  • 505 Answers
Lcd panels (screen) are very expensive and usually run almost the cost of a new set. if you can find another one with different problems (with a good screen) you can fix for cheaper, but it is not typically cost effective. Check www.ebay.com for same model # broken tvs for part, or check www.craigslist.org
Posted on Dec 09, 2008
Lg reset
Sounds like the LCD digitizer which either broke inside OR became disconnected. If the impact was not enough to sustain a screen crack, and you have warranty with either LG or through your carrier, you can get LG to fix it free if there is no physical damage, cracked screen, or water damage, with your carrier, it would be the easy, just tell them the screen isn't broken, the phone is intact but the screen is blank. That is a hardware failure... they are supposed to be able to withstand some drops so it really depends on how much physical damage there is.
A digitizer LCD is not expensive and there are ways to change them fairly simple since the screen isn't cracked, you go through most LG phones via the back, remove the camera, remove a black cover that holds the sim and or memory card, BE CAREFUL and please look at youtube to see a complete disassembly of your particular LG phone.
Jul 16, 2014 | LG Cell Phones
I have vertical lines on lcd tv due to something hitting the screen but no physical damage/crack. Can it be fixed and if so, how expensive?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Screen-shots to defective LCD are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Jun 28, 2014 | LG 50PJ350 50" MULTISYSTEM LCD TV FOR...
I dropped my Asus eee pc 1001px laptop and now the right side of my screen is covered in multicolored vertical lines. What might the problem be, other than the fact that I'm clumsy?
Your LCD panel is cracked. It needs to be replaced. Generally physical damage to LCD panels is not covered under warranty by manufacturers, so you are better off going to a PC repair shop and have them order the replacement screen for you. If you are comfortable taking apart the system you should be able to find a replacement screen on ebay.
Jul 06, 2011 | ASUS Eee PC 1001P Netbook
Broken screen
If it's physically broken then it's not repairable and must be replaced.
It's not even that straightforward though as the 32" LCD screen unit is the single most expensive component in manufacturing your tv and the supply and installation of a new screen will cost as much if not more than the cost of a brand new model.
If you have accidental damage insurance then now is the time to consider making a claim.
Nov 10, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Boys wrestling in the living room and knocked my 32'' Samsung LCD LNS3241D from the tv stand, fell flat to the floor and now there is no picture, just different color lines on the screen,no sound, nothing...
It can be fixed by only by replacing whole LCD Panel. It is expensive (usually about 500-700 for a 32"). You have to take the whole TV apart to replace the part. It will not be covered by any warranty because it is physical damage and very easy to tell just by visual inspection.
Oct 05, 2009 | Televison & Video
Lcd screen has a visual whole ... can it be repaired>
LCD is fragile screen, you screen may be damage even when your finger point in. If you still have warranty, claim for the replacement. Otherwise, if you are in OOW, it is costly if you want to replace the new one. So, you have bad luck then.
Aug 17, 2009 | Samsung LN-T3253H 32 in. LCD Television
Is it possible to replace a broken lcd screen on the Sharp LC-42D64U or is it just toast?
Sorry to say, it's pretty much toast. The screen is most of the cost of an LCD TV, so if it gets physically damaged you're better off replacing the set.
May 08, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Lcd screen is broken
Normaly physical damage is not covered by warranties. Some vendors and manufactures sell additional insurance to cover such type of damage. You can also check with your home insurance in case your home insurance policy covers damage to appliances.
The cost of a screen replacement could easily exceed the cost of replacing the complete TV set. This type of service is normaly not done.
Jerry G.
Apr 26, 2009 | Televison & Video
Sharp aquos lc - 42d43u lcd inside cracked
Normally warranty does not cover this kind of physical damage to your lcd screen. First check with your vendor to confirm. To replace the lcd panel is very expensive, may cost you as much as to buy a new one.
Jan 04, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
627 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
