Question about Mitsubishi VS-50111 50" Rear Projection Television
Sound but no picture
I had a simular problem before
and it would seem to correct it
self once it warmed up but now
when I turn it on I get a distorted
picture in the middle 65% of the
screen for 10-15 secounds and
then the screen goes blank.
Any suggestions?
  • dhdegregory Dec 12, 2008
    no the light does not blink
  • 121 Answers
Convergence circuit problem. probebly bad intergrated circuit and burned resistors. normal for screen for screen to shut down. not easey repair, prob need tech. repair 200.00 avg. usally in home.
Posted on Dec 09, 2008
  • 4,234 Answers
This is most likely a problem with the convergence circuit at the least. Does the standby light blink? It should be blinking if the internal diagnositc circuit has kicked in. This code will help to indicate the circuit in which the problem exists. Please update this with that info.
Thanks,
Dan
Distorted Screen
This tv have a problem call convergence.The convergence board require to change 2 STK convergence ICS and some or all it resistors.U have soldering iron tools and solders?U know how to solders?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 27, 2010 | RCA R52WH73 Projection Television
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
Picture is distorted on my toshiba 42h83 audio is perfect. started with this problem slowly and was able to correct by switching between tv/video selections. Now picture is distorted all the time.
Distorted in what way WAVEY? there is a problem in the past with 11 very small capacitors that can cause this did it help when it warmed up? The trouble is these capactors can be replaced. but it take someone whe can do very difficult solder called surface mount. i do maybe 2 a month its very labor intensive i am not saying this is the prblem but this set does have that history
Dec 10, 2009 | Toshiba 42H83 42" Rear Projection...
My picture is distorted at the top of the screen .
What you need to do is seek prodessional assistance and it's actually going to be either your bulbs are going out and/or the cpu board in your television is going out and once fixed that will solve your distorted picture issue. It may even be cheaper to buy a new television.
Sep 28, 2009 | Toshiba 57H82 57" Rear Projection...
Bad color and picture
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 02, 2009 | Hitachi 50UX57B 50" Rear Projection...
Picture all distorted cold warms up ok
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Dec 06, 2008 | Toshiba 57H82 57" Rear Projection...
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
MITSUBISHI VS-50801 50" TV
Bad convergence IC possible - It's cheap if you do it your self, expensive if you take it to a repair shop. My Toshiba finally came on and stayed on after the IC's burned completely up and smoke poured out the back. Then mine stayed on with a distorted image. A good place for parts -> http://www.electronix.com/catalog/default.php/cPath/6
Apr 29, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
