Question about iLO (2 GB) MP3 Player
ILO powers itself off during playback
I've had this 2GB unit 2 weeks, and I really like it. But it does this one annoying thing... during playback, it will restart itself at the end of a song. Once it happens, it will continue to do it at the end of the same song until I delete it off the player. Any ideas????? TIA!
Your problems are only begining...Turn it in if you can..I have been trying to get the firmware to flash my 2g iLO mp3 and no luck..No support for their product!!
Posted on Mar 07, 2007
Change the setting to to play all not repeat option. This is the same thing that happened to me and I changed to play and it stopped doing what you posted. Sgt.Matthew H. Tartaglia (Ret) US SAR TASK FORCE
Posted on Mar 06, 2007
T.V. turning on
yes my 26" sharp aquous LCD does the same thing, turns itself off and on at random times without explanation. I sent to authorized service center they replaced the power supply under warranty then it failed within 6 months and neither the repair center nor sharp will do anything about it other than sell me a new powersupply for $425.00. I have contacted a power supply repair center in Texas who has vowed to fix it once and for all. We'll see in the next week if they fix it or not.
Oct 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Cannot download
Make sure the lock/hold is not engaged
"Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
Download the correct Firmware
Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware
Click Open to initiate the download
Double click on the ILO or Siren folder icon. There will be 14 icons.
There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
Then click Run - this will open the Install Wizard.
The Install Wizard has the instructions on the screen as you go through it.
Once the firmware has installed, please click the Start menu, then Programs.
Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start".
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
"Found new Hardware 'SMTP3500".
-Tha Mp3 Doctor
Sep 25, 2008 | iLO (2 GB) MP3 Player
ILO Recorder DVD05R - Playback jumps 10min, 20 min and more...
Does the disc still play in other dvd player? My ILO has always been picky to play rentals so I just have a cheap COBY player hooked up to front inputs of my ILO. I use it to watch the dvds, only use the Ilo to record. Saves wear and tear on my ILO but cannot find a universal remote to operate them both and my tv. If it still records okay thats what I would do, just watch the discs in a secondary unit. Sounds like time to start shopping for new recorder.
May 04, 2008 | iLO DVDR05 DVD Recorder
My ilo won't be found by my laptop or pc when I plug it in
I need the manual to download songs or MP3 files to my MP3 Player. Help...
Apr 24, 2008 | iLO (2 GB) MP3 Player
Ilo 2gb mp3 player
the computer has not have the right thing to play your iLO. I would look at the owners manuler and see what your computer needs or inserted the iLO CD
Mar 30, 2008 | iLO (2 GB) MP3 Player
No memory and recognition error
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 12, 2008 | iLO (2 GB) MP3 Player
Ilo (2GB) Turns itself off when hooked up to the computer
hi bharder20
try to look at www.microsoft.com to see if their is a solution
my email is 62992murray@gmail.com
Jan 13, 2008 | iLO (2 GB) MP3 Player
ILO mp3 player stopped working
2)
Jan 12, 2008 | iLO (2 GB) MP3 Player
ILO DVDR05 makes high pitched squeal during recording
Usually a problem like this has to do with d.c. power sypply problems. Because "record" uses a different supply voltage and maybe "subcirckit" [not the same dc voltage that you use for playback, etc] If you know HOW to look inside and if you know how to take voltage\current readings...check ALL capitors,the diodes(misspelled?)Replace any that are "swolened", they are bad Other then that, take it to tech who if he is a crock he will overcharge, and if he is honest will repair for a fair price..... " Rotosa Ruck " [lots of luck]
Aug 19, 2007 | iLO DVDR05 DVD Recorder
iLO (2 GB) MP3 Player Logo
53 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
