Question about Dishwashers
Amana dishwasher not draining
What do I check besides the hose line to see why dishwasher not draining and then how do I fix it?
SOURCE: GE Dishwasher GSD4020Z07BB is leaking water and doesn't drain
yes...mine leaks at the door base as well
Posted on Jan 30, 2008
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
  • 171 Answers
SOURCE: Water won't drain
Hi fixitfran,
I'm Harvey the Master Plumber.
Your problem is: You have pulled the dishwasher out and checked hose. No kink in line. You have taken cleaned out dishwasher and no clog. You poored water into dishwasher and it drains from the bottom not throught drain hose. You have checked the drain hose on the bottom of the dishwasher and to no avail....you don't know what is causing this issue....can I help you out with this? LG-14AW3 Dishwasher does not drain properly and then powers itself off mid cycle. Filters are clean and there are no kinks in the drain hose. How do you fix this and will it be very expensive.
Have you recently replaced the garbage disposal? Sometimes the installer forgets to remove the knockout plug. All of the disposal manufacturers plug the d/w connection in case it is installed where there is no d/w. If there is a d/w, the plug must be removed.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
SOURCE: my danby countertop dishwasher won't drain
the problem has not been resolved. does not drain.
Posted on Jan 18, 2009
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
My Amana dishwasher will start the cycle, but will run for a couple minutes, then cancel and drain....help!!
see the cause and fix it: God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jul 21, 2012 | Amana ADB1400AWB Dishwashers
Tip
How to repair or fix a Dishwasher if it doesn't drain
Dishwasher Doesn’t Drain Following a cycle, a small pool of clean water inside the tub is normal. An excessive amount of water means the pump isn’t pumping water out properly, the drain hose isn’t carrying it to the drain pipe, or the house’s drain lines are backed up.
If dirty water spews from the air gap, the drain line is kinked or clogged. (If you’ve recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made; see your disposer instructions.)
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a stiff wire, clean it out. Also check the entire length of the drain hose for kinks or blockages, especially at the drain connection to the disposer or drain line.
2) Once the dishwasher is cool, shut off the power to it, and—if your dishwasher is made to allow this—remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If the dishwasher still doesn’t drain properly, the drain hose may be clogged or the drain valve may need replacement. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose or replacing it with a new hose.
on Sep 03, 2010 | Dishwashers
My dishwasher will not drain! Where is the drain located? Please help!
Your dishwasher may have a simple 'drain hose plugged' problem.
Check this first.
The drain hose leads out of the dishwasher to a drain, normally under
the kitchen sink. Pull this line from the dishwasher off its connection
on the drain (Nomally just a clamp of some sort) and make sure it does
not have something caught in the line, like a piece of food or something.
You could even shove a wire up the hose line after its off to make sure it
is not plugged farther up the hose line.
If this looks to be clear of abstruction, then you will need to pull the
dishwasher out of its cabinet position and inspect the underneath
of the dishwasher. If the line looks attached and no leaks or broken line,
then it may be the dishwasher pump it self that is faulty. One other thing to check
first before you call a repair man to replace the pump, is make sure you
have power to the pump. There should be an electrical connection
to the pump. Make sure it is attached, therefore power to the pump.
If it is not attached it may have just come lose, and it would be a simple fix.
OTHERWISE - - this ll fails, call your local service repair man to replace
the drain pump.
Feb 25, 2011 | Tappan Dishwashers
Will not drain water
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Amana 24 in. ADB2200AW Built-In Dishwasher
Dishwasher won't drain--Maytag Quiet Series 300
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Mar 22, 2010 | Maytag MDB8751BWQ 24 in. Built-in...
We have an Amana dishwasher, model ADB1500AWW that will not drain.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 22, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
New Amana dishwasher leaving (dried) food particles on the dishes/not cleaning well
CHECH YOUR DRAIN HOSE. IT SHOULD HAVE A HIGH POINT SO THE DRAIN CAN DORK PROPERLY. THE HOSE COULD BE TOO LOW UNDER THE SINK AND DRAINING BACK INTO YOUR DISH WASHER. OR YOUR GARBAGE DISPOSAL HOLE CAN BE CLOGGED
Oct 28, 2009 | Amana 24 in. ADB1500AWS Stainless Steel...
Water won't drain
Hi fixitfran,
Thank you,
Sep 27, 2008 | Dishwashers
The water does not drain out. Water in tub bottom
hi Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Sep 13, 2008 | Amana Dishwashers
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Dishwashers Logo
222 people viewed this question
Top Dishwashers Experts
