Question about Kenmore 44042 Front Load Washer
I THINK MY WATER PUMP IS CLOGGED IN MY 417.43042200
I'VE HAD THIS PROBLEM BEFORE WHILE IN WARRANTY. IT WAS CLOGGED BY CHANGE BEFORE. HOW EASY IS TO CHANGE OUT. MY HUSBAND IS A MECHANIC
  • 5,911 Answers
The following link will explain the steps necessary for checking the drain pump for clogs:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If your pump does not have a clean out trap, simply remove the inlet and outlet hoses on the pump and inspect the impeller for obstructions. Make sure you also check the inlet hose where it connects to the bottom of the wash tub. I have personally found small articles of clothing trapped in this area. I hope this helps you.
Posted on Dec 09, 2008
1500 dodge ram I've change the water pump 4x with
when you refilled the cooling system did you put anti freeze back in it if not straight water is not sufficiant anti freeze is a lubricant for the water pump seals which could be the problemit is a must in these newer cars &trucks now it is not recommended it is demanded
Mar 10, 2013 | Cars & Trucks
1995 Ford E250 4.9l . I've got to change the 6th oil pump . this one lasted 10 miles
There are only a few things to check. I do not have a blueprint for this engine in front of me. There may be a pressure relief valve on the oil pump assembly and the spring is broken and allowing pressure to bypass.
Oil pump shaft- often there is a spring pin to secure the shaft to the gear driving it. If the pin is sheared the pump will not spin.
Clogged block, clogged cylinder heads, oil pump pickup fell off pump?
Too much play in bearings. Cracked block.
Was this an engine Salvaged from the Obama Gas guzzler Program? Those engines were treated with an oil additive to seize them up. Parts from these motors are junk. Don't use the used oil pumps.
Please rate my info.
Jan 26, 2013 | Cars & Trucks
TILE SAW WON'T SPRAY, PUMP AN MOTOR RUN CHECK FOR DEBRI HOW DO I CLEAN TUBING TO SPRAYER I THINK IT IS CLOGGED
Make sure pump is submerged i water
Remove tubing from pump discharge and see if pump is pumping water/ If so your tubing is clogged between pump and saw. Remove tubing and rinse out with hose.
Nov 28, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 12, 2012 | Kelvinator Dishwashers
MY CONTOUR IS OVER HEATING
Most people think of this is a common problem of the thermostat. To make sure it is not the only problem, run your car a day or two without the thermostat to make sure it is not overheating anymore, then put in a new thermostat. Your problem is solved.
However, if your engine still has overheat without the thermostat, then there is a problem with restriction of coolant circulation through the engine from 3 followings:
1- Radiator clogged up.
2- Water pump is bad.
3- Water jacket is clogged up.
A shop can easily determine if the water pum bad or not.
Make sure to find a reputation shop since a yo-yo shop can change your water pump first then later on determine the clogged up radiator is the culprit while you are not actually needing a water pump at the first place. Why, a good water pump still causes overheat since the radiator is clogging up. My advise is not to use a rebuilt radiator, go with a brand new one. It can last you 10 years instead of 2 years on the rebuilt one. Good luck.
Sep 13, 2010 | 1998 Ford Contour
The pump is not pushing water through. Wat is the
ure the propeller and shaft turn, but I woulsd dare to say that they are actually turning independant of each other. Sort of like a stripped nut on a bolt. They both look like they are in place and working, but when you add any sort of pressure they just don work the way that they are supposed to. I bet the shaft is actually spinning inside of the propeller, as soon as the water pressure is built up, it fails. Spinning it with your fingers will not imitate the real life pressures exerted on the propeller and shaft, that the water pressure exerts under load (in operation). I would either rebuild it with new parts (new shaft and Propeller) or just go out and buy a new one with a warranty. There is no other reason why this pump will jnot throw water through your system... NO REASON, unless you have the thing hooked up wrong, but I think that would be impossible, wouldn't it?
Apr 24, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
92 chevy caprice water pump pics
You can get like a chilton book for the car at autozone for around 20 bucks.This is a rear wheel drive car and the water pump is easy to get to. Remove the belts and remove the fan and where what the fan bolts to is the water pump. remove the hoses and a half dozen bolts and pry it off. And the best part is the water pump at autozone with a lifetime warranty is 30 bucks.
Apr 05, 2010 | 1992 Chevrolet Caprice
Change the water pump
if its a v6 you need to remove the pump. Its about 7 out of 10 ten being hard 0 being easy
May 02, 2009 | 1995 Toyota 4Runner
Kenmore 44042 Front Load Washer Logo
131 people viewed this question
Sal De
fordexpert
Robert Rankin
