Question about Cannon Canon i960 Photo Printer
Printer won't work
My printer was working fine, now it won't even come on or power up. I took it to a repair shop and they say I need a new "card" or in spanish "tarjeta", that cost $180. Would I be able to fine one online or is that the right cost? Also would it be better just to get another printer or could it be another problem?
  • 624 Answers
Roni1, I wouldn?t pay $180 to repair a printer with three or four year old technology. I?m sure there is a difference in printer costs in Panama but here in upstate New York you can pick up a new name brand photo printers that range between $100 and $200 and that comes with a warranty.
Posted on Feb 25, 2007
It was working fine, now won't even turn on...any suggestions?
HP is making "disposable" printers. They have "repair kits" available but to repair a printer you need some quite advanced knowledge and practice so my best advice is that you should take it to an authorized HP service
Aug 13, 2015 | HP Officejet Pro 8600
My canon XP3000 won't print--5 amber flashes--cleaned printhead, over and over I took cartridges and printhead out, made sure everything was properly clicked into place, turned the thing off and on and...
Maybe. Sounds like the print head is fubar and Canon charges a fortune for them; it is cheaper to get a new printer in that case after checking it out.
Before shopping you might want to try a hard reset of the printer and reinstalling the software after uninstalling the prior software. If still bogus then .....................
Aug 28, 2017 | Canon PIXMA iP3000 InkJet Photo Printer
Looks like dead. when powering on, control panel shows "self test" and then nothing shows up on the panel and printer is dead.
Try to reset the memory on your HP Officejet. Do the following:
  • Turn off the power to the HP Officejet and unplug the power cord.
  • Hold down the "# + 9" button.
  • Reconnect the power cord and continue holding the button for another five seconds.
  • Turn the HP Officejet on, and the memory should be reset.
If this won't work, you can try to upgrade the firmware but you can only do this if the printer is still detected by the Computer. You can check control panel and see if the printer is listed as "online" or "ready".
If the above steps won't work. Your printer is deem defective and needs to be replaced. You can try calling HP support for more info. Here's their US number: 1-800-474-6836
Hope this helps.
Jul 07, 2011 | HP Officejet 5510 All-In-One Thermal...
I plugged in the priter by mistake to a 220 volt power socket and it is not working since. What do I need to do/replace?
Attend your local computer shop, select new printer, remove credit card from pocket, pay for new printer, exit shop, install new printer, throw old one in the tip
Oct 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Cannot find repair shop for canon multipass mp730
In my opinion it would cost more to have it repaired than it is worth. Unfortunately, inkjets are designed to be thrown away when they break.
I don't know of any ink jets that have lights?
Feb 03, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Displays "cannot clean" when installing new black cartridge.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 11, 2009 | Brother MFC-3240C All-In-One InkJet...
Alarm and power probelm
If you already took the printer apart, check the socket where you connect the printer to power, check that the connector soldering joints and contacts are not broke.
The circuit area near the AC adapter socket on the printer is the power board.
If there is a fuse check it.
If there is smell or trace of burnt, that means that a component, usually a capacitor, had blown.
If you do not find anything it must be the AC adapter terminal cable, or the connector , that has a broken contact.
To test it you need to get a multimeter and measure voltage from the AC adapter connector. Alternatively take the printer to a repair shop , tell them that you want to buy a power adapter for your printer, and ask to test a spare power adapter first. Many shops do not charge repair fee for this, as long as it can be done on the fly, and printer must not be left in for repairs.
Nov 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer quit working
try a test page first to determine that the printer has basic abilities.
http://tinyurl.com/6qcpgy
Aug 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cannon Canon i960 Photo Printer Logo
71 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
