Question about Canon PowerShot G7 Digital Camera
My canon g7 suddenly turned off resulting...
My canon g7 suddenly turned off without retracting the lens, I pushed the lens in gently, but now it wont start and the cover over the lens doesnt close completely... Please help
  • Anonymous Jan 24, 2009
    Same exact thing hapened to me last night. Have no idea what happened.
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Partially closed lens when powering on Canon A520 Camera
This is a fault that Canon should know about- it may mean a replacement camera- therefore Canon Technical Support should be consulted.
Posted on Jun 26, 2007
SOURCE: Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Posted on Feb 01, 2009
fotomohamed
  • 305 Answers
SOURCE: Canon G7 lens get stuck with no liveview image.
ur lens belt got creck send it for replacement
Posted on Jun 18, 2009
t00nz
  • 4738 Answers
SOURCE: Any advice on a sticking lens cover on the canon G7
This blog post outlines repair procedures for stuck lens covers. Recommend trying reader "Jeff's" fix first shown in the comments section.
Posted on Jan 20, 2010
bowlingfan1
  • 3 Answers
SOURCE: canon g7 dead wont turn
That's a loose screw issue inside the G7 and the G9 that is common. The best place I know to get help for that one would be camerasandparts.com They just specialize in the powershots and they are awesome if you need help with one of these. Best of luck, they have your exact G7 no power problem right there on their site. I hope that helps.
Posted on Jun 17, 2010
Lens error, restart camera lens does not retract possible lens moved
Try to make the lens move again by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Jun 20, 2010 | Canon PowerShot SD850 IS Digital Camera
Lens wont retract so camera turns itself off
If the lens will not retract, and you cannot get to the menus, you need to have it repaired or sell it for parts on a site such as Ebay.
Since it is not working anyway, you may want to try the following, be warned that it can cause more damage, as the camera turns on, push on the lens in a gentle twisting motion. Do this until you see it retract, or it will not fix. At that point, you have to make a decision.
Nov 08, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error,,restart camera.,,the lens wont go back in ,,and the camera will not work,,,its like the lens is stuck,,,can any one help please!!!
Did you try replacing the batteries? If that's not the problem, then it might just be stuck. Look to see if the lens is a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
Aug 01, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Jun 17, 2009 | Canon PowerShot G7 Digital Camera
Canon g7 dead wont turn on My Canon G7 wont turn on. I have tried new battery without succes. Please help nlthomsen@hotmail.com
May 27, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Cannon G7 need help
Hi
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Camera dropped, lens won't retract or expand
Sounds like the lens got bent out of alignment. Call Canon at 1-800-828-4040. They are really good with their support with or without warranty. You can send it in for repair or ask for the Canon loyalty Program. You trade in your broken camera and they'll give you a newer model for an incredible price.
Sep 05, 2008 | Canon PowerShot A560 Digital Camera
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
My Camera
the lens is bent or otherwise stuck inside the camera, unless you replace the lens, there is not much you can do i'm afraid
Aug 18, 2007 | Canon PowerShot A420 Digital Camera
Canon PowerShot G7 Digital Camera Logo
203 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
