Question about Fahrenheat Electric Convector Baseboard Heater, 3'
Heater is not heating up.
Posted by dogmanwayne on Dec 07, 2008
I am installing a noma 1000 watt heater. Controller is a line Noma line voltage double pole thermostat, wiring 12\2, breaker double 20\20. I am not getting heat. The red\black are from the breaker to line at each thermoatate terminal, load is again black\red from each terminal. At the heater I am getting 120 volts at each wire red and black. The black is connected to the black of the heater and the red to the white at the heater by wire nuts and the copper to ground. With the thermostat on I am getting no heat... I thought it might be a defective heater and exchanged it... the same problem. Any ideas? Thanks Wayne
  • Anonymous Mar 12, 2014
    I have a Fahrenheit fzl4004b wall heater. It has been in storage for several years, but prior to that had little use. I just re-installed it, and it will not turn on. I am getting 120v on red and black, but when turned on, nothing happens, no heat, no fan! Any suggestions
    Problem Solver:
  • 14 Answers
First, is this a 120 VAC or 240 VAC heater? 120 VAC heater will usually have one Black & one White wire and 240 VAC heater will usually have two Black wires or one Black & one Red wire. If it is a 120 VAC heater then you need to supply the white wire at the heater with a neutral (white) wire from the breaker panel. If it is a 240 VAC heater then you need to verify that you have 240 VAC at the heater from Black lead to Red lead. If you are not sure about how to do this please have an experienced electrician look at it so you don't get electrocuted and/or burn up your new heater. Hope this helps!
Posted on Dec 10, 2008
Setting the controls for heat and time on Noma oil filed heater Model EW7507CE
Try Googling (noma)(EW7507CE)(manual) without parens for information.
Jan 07, 2018 | Heating & Cooling
Noma model ew7507ce
There is a thermal disc inside the heater that will tell the heater if it is getting too hot to shut down. When the disc cools off then the heater will start up again. After a wile the disc gets weak or it gets stuck open not allowing the heater to turn on. You will need to replace the disc or purchase a new heater as parts for those are not easy to find.
good luck
Apr 14, 2014 | Honeywell Heating & Cooling
NOMA 1000 watt Photoelectric Timer manual
1) Copy following link to identify timer and download possible manual:
2) If timer has gone defective, then N1502 has 1 year limited warranty.
Timer is rated for 8 amps.
125 volts x 8 amps = maximum 1000 watts
2-prong output.
3) For heavier duty timer, with 3-prong grounded output, choose N1506 timer
Dec 04, 2012 | Hardware & Accessories
I have a noma Model HTM211A connected to a fan heater , element comes on but fan won't
Maybee the fan is 120v and the heater is 240v ? model number of the devicee would help
Dec 11, 2011 | Hardware & Accessories
Noma ew7507ce manual
Timer is not identified.
Noma is a recognized brand name that is licensed to many different product manufacturers for a variety of different products including timers.
Check resources below:
1) Add a comment with clear description of timer, and/or post a photo on flickr and include link to photo
2) Open following link to see various Noma timers and download possible manual:
3) If you have different product than a timer, for example an oil-burning radiator or electric baseboard heater then re-post question on fixya with clear description of product for possible research and information
Oct 03, 2011 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Noma outdoor timer 1875
Noma is generic brand name used by different sellers to denote that product is a timer.
Noma is generally associated with Woods timers.
1875 is usually the watt rating for heavier duty timers, like 2 button block heater timers, etc.
1) Add a comment and describe timer in detail, and include photo of timer posted on Flickr for possible identification.
2) Open following link to find same-similar timer
Aug 19, 2011 | Hardware & Accessories
I am haveing the same problem.........., the first 10 i installed no problems....... now the last one i am ..............did you have any luck
Nov 12, 2009 | Heating & Cooling
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
Oct 04, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Fahrenheat Electric Convector Baseboard Heater, 3' Logo
402 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
