Question about Lexmark X125 All-In-One InkJet Printer
For Lexmark X125 add right cartridge
Says add right cartridge. Have put in new and used cartridges(which also worked in my other lexmark. A Lexmark tech email team tech tried to solve it thru a series of solutions but none worked. I just called the 800 # which I discovered is not in US and they have no service centers to repair this model anymore. Anyone have any ideas, before i toss it.
Some one told me change NEW RIGHT 3 times
Posted on Jul 31, 2010
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
Lexmark x125 system error after installing new inks
All cartridge installation and level reporting is done through the printer itself, not the software. You should ensure the X125 has the cartridges installed in stand alone mode first. To do so, open the lid and remove the cartridges. Then unplug the power cord for one minute. Reinsert the cartridges, connect the power cord and close the lid. When the lid is closed, the display will ask you if "New" or "Old" cartridges were installed. If new, align the cartridges, if asked to do so. If this still presents you with a "Change Cartridge" message or something similar, please try a different cartridge.
Sep 30, 2009 | Lexmark X125 All-In-One InkJet Printer
Lexmark x125
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Installing ink cartridge in Lexmark X125
The front panel is hinged at the bottom so grab the top and pull towards you.  Under that is a protective cover, the one with the 2 paper guides.  towards the bottom of that there is a hole in the middle.  Put your thumb in it and lift the cover up.  Your carrier for the cartridge is under that.  Please Rate!
http://www.lexmark.com/publications/eng/x125/index.html
That link will give you the manual..just in case you need it.
Mar 11, 2009 | Lexmark X125 All-In-One InkJet Printer
I can't put cartridge back in printer
put the bottom of it in first and then press the top toward the back of the printer.
Lexmark x125 all in one won't print from memory.
Did you go into your printer properties and select new cartidge installed?  If this doesn't work, take the cartridges out and clean the contacts on the side and in the carrier with a qtip and rubbing alcohol.  Give it a few minutes to dry and reinstall the cartridges.
Jan 10, 2009 | Lexmark X125 All-In-One InkJet Printer
Lexmark X63 all-in-one printer shows "add left cartridge" after I already did and subsequently I receive printer busy message when trying to print. Worked perfectly before new left cartridge...
try powering off the printer for 30+ sec.... then turning it back on...
unplugging/replugging the cartridge and doing maintenance cycle
the printer's sensor are acting up and Lexmark won't really share how to reset these things, neither offer "logical" tips... The info given here was pretty much the Lexmark troubleshooting steps...
HTH
Aug 16, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Lexmarkx125 printer
same issue with me, using a genuine cartridge... cartridge sensor is probably stuck or hung... i know of possibilities to "trick" the sensors on refilled cartridges... i just don't have the documentation for that anymore... it came with my ink refill package
May 24, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Lexmrk x125 all-in-one printer
As you do not have the disk with you, rather than finding the disk you can get all the software, drivers. manuals( user guide ) on the website. It is available free for you to download. I have mentioned the link below
http://support.lexmark.com/static/229-1-0-346.html
Hope you find all the info you are looking for on this link.
Will wait for the ratings.
Thanks
Sammy
Dec 05, 2007 | Lexmark X125 All-In-One InkJet Printer
Lexmark X125 All-In-One InkJet Printer Logo
175 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
