Question about Emerson SB350 13 in. TV/DVD Combo
No sound from the DVD player
The DVD player plays dvds but there is no sound. I have checked all the cable connections in the back and they are fine. And yes, I have checked the volume setting - even on full volume, no sound. Any ideas?
    Problem Solver:
  • 11 Answers
This problem is by setting of dvd your sound its for system pal,secam or ntsc this its your problem
Posted on Apr 15, 2007
  • Keri Cowart
    Keri Cowart Oct 04, 2017
    I'm sorry, but what does that even mean? I'm having the same problem.
I can't get the DVD player to view dvd on tv
hi konni.
this is all i could find .
DVD player not working with TV By Charlotte Parker 25 Aug 2017
You've got your Sky Box, your TV, your DVD Player and your surround sound; you've also got your digi-box, your DVD recorder, Blu-Ray Player. With all that equipment, if something goes wrong it can be tricky to track down the issue. This article explains why your TV isn't playing DVDs and how to get it sorted out.
Figuring out the problem
Figuring out why your DVD Player isn't working with your TV is a process of elimination, so work through the steps below to figure out the cause of the problem.
The problem could be:
  • The connector cables/connections.
  • The DVD disc itself.
  • The DVD Player's optical reader (the lens which 'reads' the DVDs).
  • The TV.
Before doing anything, check all your connector cables. Make sure that all connections are in properly, and that the cables are in the right place.
One of the most important connections is the cable that runs between your TV and the DVD Player. If it isn't in place, then your TV can't read the information from the DVD Player and the film won't appear on your TV.
The DVD disc itself
Check for scratches, chips, smudges and any other marks. Test the disc isn't the problem by trying a different one in the player. If the new disc works, then the first one might need replacing.
The TVTry changing channels. Lots of TV's have a default channel specifically for DVD players. Have a look between the channels to see if the DVD menu appears.
On modern televisions, especially those connected to Digi-boxes or Sky Boxes, there's usually a 'Source' button on the remote control. Find it and go through until you reach the right setting for playing DVDs. To go back to watching normal TV channels after the DVD has finished, go back to the source button and change back to the original source.
That should be all you need to know to get your DVD player working with your TV
if none of above works then try putting a lens cleaner through it to try and clean the lens that reads the disc.
Nov 05, 2017 | Televison & Video
Dvd pplayer will not play but vcr is fine
If both connect at same exact place on set the player itself may be bad--you get sound from the DVD unit?
Dec 12, 2012 | Televison & Video
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
Up until yesterday our dvd player was fine, today I put in a dvd and there is no sound. I have put a couple of dvds in and there is no sound except for one dvd I put in this works fine?
the dvds you put in are not compatible to your dvd player.but you can clean the lens and see what it does.good luck.dvds work with region.check the region of your dvd player and dvd you are attempting to play.
Mar 04, 2011 | Televison & Video
Suddenly no sound from playiny tv through the dvd
check SCART lead hasn't come out....even a slight amount will disconnect the audio pins
Check the function / to others / setup / connection / AV1 & AV2 settings
Feb 15, 2009 | Panasonic DMRES20D DVD Recorder
Toshiba 40" 1080p plays dvds with a red tint and no sound??
When connecting the dvd player using component cables and audio cables, go to the progressive scan setting on the dvd player and select it. Once I activated the progressive scan, the problem was solved.
Jan 26, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
DVDs are playing with green tinge
Greetings and Salutations,
If your using the component outputs from your DVD player I would first check to make sure that the cables for the Red and Blue channels are connected properly. If the cable is connected correctly then try replacing both the Red and Blue channel cable. If this fails to fix the problem try connecting to another component input on your TV if you have one available.
You might also want to check to see if you switched on the progressive scan switch on the back of the VCR/DVD unit. If you know someone with another DVD player have them bring it over and see if the problem is still exists.
If the green picture is still present then the problem is and internal problem with the TV and you will need to find a repair center for it. If the problem goes away then the problem is with the VCR/DVD combo unit. You can at this point also try using just the Video Out from the DVD player.
Hope these suggestions will help you with your problem.
Jan 06, 2009 | Toshiba SD-37VSR Player
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
The insigina combo
i would check the tv TO DVD/VHS COMBO connections OR REPLACE OLD AUDIO VIDEO CABLES especially if the tv plays clearly.
Dec 11, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Emerson SB350 13 in. TV/DVD Combo Logo
165 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
