  • gabrielbailo Dec 09, 2008
    thank you very much!!!!!!! yeah very expertise level thanks!!!!
    which one will you recomend for sony 53 inch iseem not to find it sony kp53s75
Mcm Electronics on the internet about 12 dollars each and you need a steady hand at soldering
Posted on Dec 09, 2008
How do i replace my convergance chip
contact parts distributors who sell convergence kits for your model.
Order instruction DVD.
Jun 03, 2010 | Televison & Video
Small horizontal red, green lines from top to bottom of screen. Less noticable on HD. Help??
Hi,You are experimenting the most common failures on sony sets:"Light engine problem" basically your tv uses 3 LCD chips that are like tiny screens that create the image and colors.When you get lines like what you are describing its affected by those chips.I will suggest to contact Sony,sometimes they are willing to repair it or give you a certain deal ,since they were in a law suit for faulty light engines.Good luck and God bless you!
Nov 10, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Lots of Blue shadows off to side. concaved picture almost
HI, this is a failed convergence chip that is located on the convergence board. it will need to be replace ASAP. you can just replace the chip or , you can order a new board.
Replacing the chip can be a rough job if you don't have tech experience. if you are a fluid tech and you can solder and know your way around a circuit board, just replacing the chip will cost less. if you are not an experienced TV tech, i recommend a service call to the nearest TV tech to replace the convergence board.
May 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP -46WT510 Convergence Problem
Yes - If you are failry handy and take your time its a DIY project.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 19, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
SAMSUNG HC-P4752W 47" TV Convergence problem
Resistors most likey...look for burnt or discolored resistors near the convergence chips.
Apr 07, 2009 | Samsung HC-P4752W 47" Rear Projection...
You can check this link for that convergence that your looking
after you replace thet convergence correctly its should be working fine already..
Good luck.........
Aug 10, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Panasonic 47 inch Projection tv PT-53WX42F
Sounds like your convergence chips are going. Unless you are real handy with soldering iron I would suggest having a tv repair shop service it(probably cost $200-300). If you are handy then I believe the chips you need are Sanyo STK392-110. There should be 2 of them. be careful if you order them online, there are lots of chinese knock-offs out there.
Apr 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Update and a few questions (Convergence Problems - VS-55601 55 in Projection)
yes, they go bad interment because they have a large current go thru them and they generate heat, they are mounted on a heat sink with white silicone to help disapate heat. replace both not just one, try MCM Electronics get heat sink compound also
Oct 06, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
