Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Wireless connection i have a westell model 327w router both wireless and ethernet are working for other computers. With my Acer TravelMate 4020 I cannot connect to the wireless network. Clearly, I am not the technically savy. Can anyone help?
  • macigewski Dec 11, 2008
    i have a westell 327w router, all the pc's in my home work fine but my acer travel laptop recognizes the router and says i have exellent signal strength, it wont connect to the internet.... i keep getting the msg that there is little or no connectivity?? and it also asks me for a network key? what is that?
    Genius:
  • 1,269 Answers
Make sure the wifi capability of your laptop is turned on or enabled.
Posted on Dec 09, 2008
I HAVE A WESTELL VERSALINK MODEL 327W IWANT TO CONNECT TO MORE COMPUTERS TO IF DO I HAVE TO HAVE SOME TYPE OF ADAPTER IN ORDER FOR IT WORK
your westell is a modem/router which means you can hook up more computers wirelessly.
yes, if you're using a laptop make sure it has a wireless card and for desktop computer..you have to have a wireless adapter...
Feb 09, 2010 | Westell Wirespeed VersaLink...
I lost the security code for my westell 327w. need to find code so i can add another computer.
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Jan 01, 2010 | Westell Wirespeed VersaLink...
I have switched to a Westell VersaLink 327W from a older Westell Wirespeed. The Wirespeed communicated via USB and the new Westell communicates via Ethernet. How do I get the computer to see the modem?
If you are using a Westell DSL modem with ethernet connection, then you connect the modem's ethernet port to the computer's network card. This also uses an ethernet cable. Good Luck
Jul 19, 2009 | Westell Wirespeed VersaLink...
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
May 29, 2009 | Westell Wirespeed VersaLink...
No wireless connectivity with Westell 327w
on the back of the modem is a reset button. try resetting and bridging the modem again.
Apr 09, 2009 | Westell Wirespeed VersaLink...
Cannot get wireless router to work with Xbox 360
Does the westell router only have 1 ethernet port, if so a ethernet hub would be better, they can be baught for about £10.
You will need to input your account settings for your broadband conection into your new router for it to work, with this router all you actually need to do is connect it to the 360 with an ethernet cable, if you want to use it wirelessly you need to buy a wireless adapter for the 360 for about £30 - £60 depending where you buy it.
Jan 02, 2009 | Microsoft Xbox 360 Console
Westell model 327w router
if this is the first time you're trying to connect your laptop with the gateway, if this is a windows operating system, you have to go to your wireless zero configuration so that windows can automatically configure the wireless connection of your laptop. you cann see that by clicking on start, and then run, and then type in the box services.msc, and then search for wireless zero configuration click on start if the service has not yet started. if this doesn't work check your built in wireless adapter, uninstall and reinstall it. try to access your westell by typing in 192.168.1.1 in the internet explorer address bar. the default username and password for that is admin and password. you can configure the wireless settings in the modem by going here. the WEP key for your wireless connection can be found below your westell modem/router. if i'm not mistaken this is the westell 327 versalink right? you can also find out if your laptop is connected to your modem by checking your computer's ip address. it should be 192.168.1.xx. if it's like this, your laptop is connected to your 327w. if it's a 169.xxxx ip address, you're not connected to the modem. the best way to configure your laptop and modem wirelessly is to configure it while you're connected using an ethernet cable.
Oct 21, 2008 | NetGear DG834G Router
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
it seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Oct 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
93 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
