Question about Samsung TXP3275H 32" TV
Excessive voltage coming from television
We have had a Samsung HDTV for a couple of years, and up till now it has worked great. The picture began showing curvature, then started going out, reappearing, going out, etc very rapidly whenever the set was turned on. When the picture would fade out, the audio would get very loud and distorted at the same time. During the days leading up to this event, we would hear loud "popping" noises coming from the set periodically throughout each day. A cable repair tech was here delivering a new HD box, and when hooking up the new cable box, he got shocked mildly. He hooked up some instruments and told us the television set was "pumping out excessive voltage", way beyond normal limits. He said that instead of using the electrical house ground, it was using the cable tv coax to ground. What would cause a television set to "output excess voltage"? What might the fix be, and what kind of costs are we looking at?
  • 49 Answers
There are 2 probable cause,...flyback transformer leak out and ur power supply goes high- v.not 4 to fix it too risky..both of this cost much..
Posted on Feb 26, 2007
Any image (even the unit's menu) is superimposed by couple wide horizontal half-opaque stripes of color sparks
If i am correct in my assumption of what you are trying to say, you are seeing a random pixel discharge. may look kind of like snow. Early on Samsung had us to adjust the different voltages used to drive the panel, but in my experience this rarely worked and the set came back for repair. Later on Samsung began to authorize panel replacements for this problem. If it is in warranty get it to a shop fast, also check you r warranty, some of the plasmas had a longer warranty on the panel part.
May 07, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Screen dim, rt. side, have replaced both mstr. & slv. v. inv. bd.
The Panel is bad. It is shorting out the power supply and inverters/ballast.
Apr 12, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Aug 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Television will not turn on
The symptom indicates that there is a shorted board or multiple shorted boards and needs to be looked at by a trained Samsung tech.
Jul 02, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
SAMSUNG PROBLEMS - Red and Green Shading All Over Screen
adjust vscan  vs & va voltages on power supply, if not that drive pcb's are bad
Jun 05, 2009 | Samsung LN-S4051D 40 in. LCD Television
Hc-p4752w will not turn on.
you will need to trouble shoot the power supplies most likely a low voltage regulator isnt functioning.
May 29, 2008 | Samsung HC-P4752W 47" Rear Projection...
2 1/2 years new Samsung HC-P4752W from Costco, Canada
Samsung makes a great product and has one of the best pictures out there. I have had mine for a couple of years and only experience a slight convergience issue on left and right sides of the screen after twenty minutes of run time. I am currently trying to figure out how to fix it.
Jan 26, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung TXP3275H 32" TV Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
