I were also getting multiple misfire codes which has been cleared but the car still feels the misfire. So i am not sure on how to fix the P103, does any one know ?
The honest best thing to do, to save time and money, is take it to a dodge dealer and get them to diagnos the problem, they have equipment that can pin point the actual problem were obmII readers only tell you what the codes are. they will probably charge 70 to 80 dolars to diagnose your car, but the end result is you know what parts to change.
SOURCE: P0302 Engine Code
Acroding to the codes it is a # 2 cylinder miss fire , sounds to me like there is a lot of carbon build up
SOURCE: code p1684 2002 chrysler
P1684 means the battery was disconnected within the last 50 key starts.
SOURCE: MISFIRE ON CYLINDER 5.
Same problem. 94 LHS 3.5L engine. Noticeable rythmic misfire at idle. Looks like cyl 5. When I pull the injector connector off of cyl 5 the idle rythm does not change. It does if i pull the inj connector off of any other cylinder. Spark OK. Injector ok using seperate 12vdc supply (clicks). Connector to injector has pulses on it verified with a test light. Inj coil resistanceis 12 ohms, exactly what it should be.
Still need to check compression and intake manifold gasket
[email protected]
SOURCE: I have a 2006 Chrysler Pacifica and the check
these codes are evap codes you have a breather line problem in your fuel system
SOURCE: Misfire
It may be that there is carbon build up. Check the bulletins for you car.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 09-005-05, DATED
DECEMBER 2, 2005, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A
COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT
REVISIONS.
SUBJECT:
Multiple Cylinder Misfire Or Rough Idle
OVERVIEW:
This bulletin involves rotating all engine exhaust valves, replacing the valve spring retainer
locks with a new design to increase valve rotation at lower RPM, inspecting/replacing the
MAP sensor (as necessary), and decarbonizing the combustion chamber.
MODELS:
2004 - 2006 (CS) Pacifica
2005 - 2006 (LX) Chrysler 300/Magnum/Charger
Of course you know how much the dealer is going to be if you are out of warranty. You can try a few things which may possible help, like getting some of the mopar fuel cleaner or another good fuel cleaner, I've heard a few people resolving the issue that way. If you need a good service manual Promanuals has one relatively inexpensive.
I already bought to the car to the dealer for a week and they somewhat fixed the misfire code. However, i am now getting this new code P0103 ? Does anyone have any idea on where to start ? I am having issues this car for the past month.
