I have a 47 inch vizio lcd. model is the GV47L FHDTV10A. i can turn the tv on. after about 20 minutes the tv will start to dim and flicker, and it will go totally black. it is making a popping sound as well. i can turn it off and then turn it back on and i will stay on for about half as long. (may be getting hot) i changed both master and slave backlight inverter boards. it now just shuts off automatically. i kept turning it back on and after about 30 minutes it started to do the dim and flicker and popping thing again. wondering what i need to do.
2 Suggested Answers
  • 58 Answers
SOURCE: Vizio GV47L FHDTV10A
sounds like a lamp failure.
Posted on Dec 06, 2008
I have a Vizio TV and would like to add a Chromecast streaming media player,the information I have shows the player powered via the USB IN 1 port,would the RGB PC port work? I have model #GV47L FHDTV
Chromecase is a USB 'stick' type device with a USB interface. The RGB port is a video only port on the TV and not compatible with USB signal levels or the physical plug type.
Jan 05, 2015 | Vizio GV47LF Television
Vizio VO47L FHDTV10A black screen no light
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Vizio VO47L 47 in. LCD TV
I'm have a vizio TV model gv47l fhdtv10a,I need
call any tv place they have new installation kits thatyou can buy
May 17, 2013 | Televison & Video
Fuse location's on vizio VO47L FHDTV10A
the inverter has failed which is a very commom problem. You can get the replacement inverter from www.tvcircuitboards.com
Jun 03, 2012 | Vizio VO47L 47 in. LCD TV
VIZIO GALLEVIA modle VIZIO GV47L FHDTV10A
Most plasma TV's have secoundary power boards, witch can be the cause, now I would try if I where you is to unplug it and let it set a hour or two, if that did not work then the tv will need to be looked at locally. The cause can be a bad power board inside the TV witch is a major cause why a Tv would have a power light put no function at all.
Hope this helps if you have any questions as to what parts to buy www.partstore.com is a best resource.
Oct 18, 2011 | LG 42PG20 42 in. Plasma HDTV
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
I need to find a technician who can replace the sound unit in my Vizio GV47L LCD TV. Do you know of any authorized technicians I can call?
Why ? this question must be asked to VIZIO company If the company will pay that is ok.
if you will pay this number is good. 8174483891.He will help you. try to call afternoon.
Sep 23, 2009 | Vizio VO47L 47 in. LCD TV
Vizio GV47L, How to replace fuses on motherboard? I have the fuses located, but never swapped these type of fuses before. Thanks
Fixed my 47" GV47L for $7.18... Did the F3 Fuse bypass solution, and it worked like a champ!!! No problems since! The part that took the longest was the drive to Radio Shack!!!r_to_the_k.jpg
Jun 03, 2009 | Vizio VO47L 47 in. LCD TV
Dec 03, 2008 | Televison & Video
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
