Question about Car Audio & Video
Faceplate Plastic Holder Broken - need to find replacement
The plastic piece that locks in the faceplate broke. looking for a replacement piece and don't know what catalog number it is and where I can replace it without having to buy a whole new stereo. Any ideas? its the Kenwood KDC 135. Thanks my plastic peice to lock in my faceplate (jvc kd-avx1) popped off, i have all pieces. Can this be reassembled easily?
F4 button pressed in
Most of the Roland buttons on this type equipment use a small switch that is actuated by a plastic button that is HINGED from a plastic panel behind the faceplate or a part of it. These plastic hinges get broken when too much force is applied to the button... it is USUALLY fatal and requires replacement of the whole button faceplate... and they are expensive... contact Roland parts to inquire.
Mar 01, 2011 | Roland Mv8800 Production Studio
How to change the faceplate of a samsung s7330
  • Locate the small plastic tab on the top of your Samsung phone, located in the groove between the faceplate the main phone body. This tab is very tiny, only about one-sixteenth of an inch wide.
  • 2
    Press on the plastic tab with your fingernail.
  • 3
    Continue holding down the plastic piece while sliding the faceplate off the top of the phone. The faceplate only slides off from the top, so don't try to force it in a different direction.
  • 4
    Release the plastic tab.
  • 5
    Line up the new faceplate with the top portion of your phone then slide it downward until it latches into place. You'll typically hear a soft click when the faceplate is secure. When properly placed, the new faceplate should not be able to wiggle or slide unless you press down the plastic tab once again
    Read more: How to Change a Samsung Phone Faceplate ' eHow.com http://www.ehow.com/how_5146822_change-samsung-phone-faceplate.html#ixzz17o6dpgG0
  • Dec 11, 2010 | Samsung S7330 Cell Phone
    Unable to remove faceplate or eject cd on kenwood
    remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
    Jan 17, 2010 | Kenwood KDC-516S CD Player
    Remove protective film wrap from under water dispenser faceplate
    I have this same model and was facing the same issue. I even emailed Whirlpool but that didn't help.
    You can remove the faceplate by removing the spill tray and unscrewing the two small screws in the bottom. Be careful not to scratch the finish while removing the screws.
    The faceplate is held on by several plastic hooks around all edges. Carefully grip the bottom of the faceplate (I put my thumbs on the inside where the spill tray was and my index finger below the bottom front of the faceplate). Get a good grip by pinching the faceplate and pull down and out to remove the bottom. Then push the faceplate up to unhinge the top.
    You can let the faceplate hang by the wires while you remove the plastic. I'd also use a stainless steel cleaner while the faceplate is off to get rid of any fingerprints you may have left behind.
    To reinstall, hang the faceplate on the top 3 hooks making sure there is a snug fit. Then pull down on the bottom and push it in. It took me two tries to get it back on.
    The plastic is stronger than it looks but you'll still have to go slow and be careful with it. Good luck!
    Sep 09, 2009 | Whirlpool Refrigerators
    My reset button is covered with a plastic piece, under a sticker
    The reset button should be located under the faceplate. Stick your thumb nail under the Garmin name and pop the faceplate off.
    May 22, 2009 | Garmin nuvi 200W GPS Receiver
    Jensen MP5720 radio/faceplate connector is broken or missing spring
    I was always afraid this might happen to me so I never removed the faceplate from the radio. This strategy worked fine for two years until two weeks ago. I didn't lock my car because of the freezing rain and somebody stole my faceplate and remote. Anyway I ordered a replacement radio from Amazon last week so I don't have rewire a new one. The replacement cost me $100. I don't really need the rest of the radio so make an offer, my email is cs1713@sbcglobal.net
    Regards, Chas
    Sep 18, 2008 | Jensen MP5720 CD Player
    Faceplate display backlight out
    Your display lights are burnt out. This is a common problem. It is covered under warranty. Send it to Sony for service. Anyway, under the Sony faceplate there are two small, different colored leds which control the color. The light is aparently transfered through pieces of clear plastic (best example I can think of is the piece of plastic over the led in a household smoke alram)to most of the buttons and the backlighting. If your display has burnt out you may just be able to swap the leds for new ones. As for the intermittent green could it just be a faulty solder on the board.
    Sep 23, 2005 | Sony CDX-CA400 CD Player
    Car Audio & Video Logo
    335 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
