New MP4 came with mini disk driver and no insturctions how to use
No instructions on how to use mini disk driver on my iMac
I wish someone would explain step by step how to use this.
Instructions that came with MP4 are incomplete and when I plugged it into my computer and turned it on the display shows a number of Z Z's and a
monitor -nothing in manual with this picture. I guess it means the MP4 is asleep -but nothing I can do or push makes anything else happen.
Please help if you can!!!!!
  • 1 more comment
  • rillbill Dec 09, 2008
    Please your answer is not complete enough -please answer all my questions
    It is a Missil Digital MP4 Player 8D-2801 that came with incomplete instructions and a mini driver disk, which I am concerned about putting into my iMac computer, as it is so small and might cause problems with my computer.
    I have the unit attached to my USB and the screen shows only ZZZZ.
    I really need step by step instructions on how to operate all the functions available.
    Thanks
  • rillbill Dec 11, 2008
    The player has a mini disk driver that does not want to be accepted by my
    iMac - I don't want to force it in and when I do put it in as far as it will go
    (into the larger slot located on the side of my iMac) it ejects it every time. Should I force it in? Don't want to cause damage to computer.
    I have connected the player via the USB connection to my computer and it
    charged the unit. I tried going to iTune to try downloading a song but can
    hearing nothing with the ear speakers.
    Opened the icon for the MP4 on my computer and see this from:-
    Stuffit Expander message -The file/Vol./MP4player/mtplist.bin does not appear to be compressed or encoded.
    Obtain further info. about contents of this file from sender or provider of the file. (The morely written User Manual) does not contain a contact number and can't locate a contact for MISSIL anywhere on the net)
    I also went on line and downloaded Xilisoft MP4 Converter for Mac and tried to download that on my player -but get the message at the end of the install that there is nothing to install - yet the downloaded Xilisoft indicates it contains 26.7 MB
    Better go back to using a manual typewriter (if they are still available, in a museum probably.)
    p.s. The pkg.containing the MP4 player had the Mac. icon on it so I assumed it would work
    with my Mac. -but maybe not.
    MAYBE I SHOULD JUST TAKE THE -- THING BACK --
    WHAT DO YOU THINK ?
    THANKS SO MUCH FOR ANY HELP YOU CAN SUPPLY!!!
    Master:
  • 479 Answers
  1. Import DVD Movies
    1.  Click the Load DVD button, select the folder of your DVD movie, and click OK. If the movie is on your disc drive, you can just select the drive and click OK.Or click the Load IFO button, open the folder of your DVD movie, and you will find two folders in it: AUDIO_TS and VIDEO_TS. Open the VIDEO_TS folder, select all the IFO files, and then click OK.After the movie is imported, you can see all the chapters and titles in it, and then you can check the ones you want to convert. If you want to convert the whole movie, you can just keep all the titles or chapters checked.Set the Output Settings. Before the conversion, there are a few settings you should make:Select an output format from the Format drop-down list. (Here you can select an MP4 format for iPod, iPhone, Apple TV or PSP).Click the Settings button to set encoding settings including video resolution, frame rate, bit rate and video encoder, audio encoding settings including sample rate, channel, bit rate and audio encoder.Name each title/chapter in the Output Filename field, and select the subtitle and audio track for the titles/chapters.Note: You can check the “Merger into one file” option to join all the selected DVD titles/chapters into one file instead of creating a separated file for each title/chapter.Conversion.Click the Start button to start the conversion.And now you can just go talk a walk and wait till the conversion is completed.After that, you can just transfer the created files to your MP4.
[edit]TipsTip 1: Trim MovieIf you just want to convert a clip from your DVD movie, you can click the Trim icon to capture a clip In the Trim window, you can trim the length of the current title/chapter by either dragging the Start Time and End Time sliders or setting the time parameters in each corresponding field.Tip 2: Crop VideoIf you DVD video has black sides, you can use this Crop function to remove them.Click the Crop icon to open the Crop window, and set the crop area by dragging the crop frame or setting the four crop parameters (Top, Bottom, Left and Right).Tip 3: Movie EffectIf you are not content with the original effect, you can click the Effect icon to set the video brightness, contrast, saturation, and audio volume.You can also choose to apply a special effect to your movie video from effects including Gray, Emboss and Negative.
Posted on Dec 11, 2008
  • 4,806 Answers
The drivers should be on the mini disk for the iMac, just pop it into the DVD and install the drivers, when you connect the MP4 player to the iMac it should wake up and you can use all the functions on it
kind regards
Posted on Dec 09, 2008
    President:
  • 2,110 Answers
Zz's means your mp4 player is already connected to pc...and u cant do any operation at this time....At this time u can see a usb drive In that u can store mp3,mp4 anything...
  • 107 Answers
The reason it show the zzzs is because it is in sleep mode while connected to a system, First unplug it from you system run the minidisc then after/durring install if prompted plug it back it. when not pluged into the system turn it on to see what it looks like without it sleeping
    President:
  • 1,073 Answers
Use the mindisc as an ordinary disc, just put in the cd-driver and run it.
Minidisc is just like an ordinary disc, just a little bit smaler, but the cd-driver runs it like any normal disc
Hopfully your MP4 wakes up after you installation
Good luck
  • 6,487 Answers
Can you please provide us the exact model and brand of this unit so we can help you better....
    Genius:
  • 1,269 Answers
The disk driver that you have might be incompatible with mac. You can try to download the mac version software of your mp3 player. You can visit the manufacturer's site.
I can not eject a mini dvd i put in the drive
The drive will probably have to be removed since the drives are not meant to accommodate such small disks. ifixit.com has guides.
Once removed, there is a flap on the end that can be unscrewed and the disk should fall out. I've done this to remove an sd card someone shoved into the slot on an iMac.
Mar 12, 2014 | Apple MacBook Pro Laptop Computer with...
Imac wont recognize my new internal hard drive
Yes, rem it is iMac, it has to be formatted for iMac, sorry there is a way, if you have alternative access, search box and type in formatting new had for iMac. Good luck.
Feb 08, 2013 | Apple iMac G5 Desktop
Disk won't go into iMac
Do you have another disc already in there?
Oct 08, 2012 | Apple Mac mini G4 Desktop
Getting a new flat panel lcd screen to work on my
It should work right out of the box, although with imac's you may need to install the software that came with the monitor first. Try Safe mode if it won't show up any other way, safe mode skips the drivers for the most part, it may allow you to see the installation disk, install the drivers and whicever app's u need from the disk. Also make sure you have the correct connector on both ends and the cable that came with the new moniitor, "not the old one", that may be it right there. The pins are different on different systems. Let me know what happened, if your old monitor works, it's a setting, try running multi monitors thru video properties menu so you can se what's the heck is goin on with the installation disk, good luck
May 20, 2010 | Apple Refurbished iMac 20-inch 2.0GHz...
No driver for mp4 player - CD doesn't work for iMac
The drivers can be found at the following website, although I'm not sure that your particular Rio is Mac-compatible:
http://www.digitalnetworksna.com/rioaudio/default.asp?cat=35
-Tha Mp3 Doctor
Feb 13, 2009 | Rio Audio Players & Recorders
Can't get the usb port to accept the mp4 player.
Switch on your Mp4 player and connect it to the usb port. Your computer should produce a message "New Hardware Detected". If you don't get such a message either the lead, the usb port or the Mp4 player is faulty.
If you do get such a message, if your computer can't find and instal the right drivers automatically there will be another message or the Found New Hardware wizard will appear. By following the onscreen instructions your computer should be able to search the internet for suitable drivers.
In any eventuality, when connected the Mp4 player should appear in the My Computer window and if it doesn't it isn't connected.
Jun 26, 2017 | Samsung YP-T9JQB Digital Media Player
X1150 Lexmark printer purchased with imac - need to install without disk
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Jun 28, 2008 | Lexmark X1150 All-In-One InkJet Printer
Eurolab 2gb MP4
This is SanDisk E250 page You have all the instructions on how to https://www.customernation.com/pls/ps/ps.ps_main?p_host=304&p_supplier=5096&p_parm=PSHPP You it will help You
May 06, 2007 | SanDisk Sansa e250 MP3 Player
Sony Mavica CD400 -- can't get iMac to see mini disks
Bob: the Mac will never show what is on the disk.....and you don't hgave to finalize either. Do you have Image Capture on your units? If so, all you need to do is connect the camera via USB cable to the computer. The program will come on automatically (the camera has to be on), you can choose to download some or all of the pictures to a folder of your choice. HTH
Sep 13, 2005 | Sony Mavica MVC-CD400 Digital Camera
 Grubhead
Grubhead
