Question about Electrical Supplies
My motion sensor stopped working--the lights are full on all day.
One flood light burned out and since, the lights are on full day and night. I had it set for a 1 minute on and dusk to dawn setting. How do I fix it?
  • sbbjfb Dec 17, 2008
    I wrote in about ny motion sesor lights that stay on. The name is Heath/Zenith DualBrite Motion Sensor Light Control with 2-level Lighting. It is about a year old. One bulb burned out and the other bulb came on bright. I replaced the old bulb,but the lights stay on bright. The sensor blinks red when I move in front of it, but the lights stay on day and night. I have tripped the circuit switch and turned the light off for days, but it still doesn't operate right. Changing the settings doesn't help. Is there any hope?
    Stuart Bliss
  • tom May 11, 2010
    Is it connected to a switch. If so try turning the switch off for a few seconds and back on. If it is not connected to a switch you may have to disconnect the power or turn breaker off for a few seconds and then back on. some units have a sensitivity setting.
    tom
    Problem Solver:
  • 6 Answers
You can get installation manuals from www.FixYa.com/Instructions+Manuals
Posted on Mar 08, 2009
I have pir movement the problem is without movement its getting on
Posted on Sep 02, 2009
I have fitted a motion sensor light (eplacing a very old unit) . the new lioght satys on all the time. there is a sepearte on off switch in the house which served the old unit . what is likely to be the problem please
Posted on Feb 06, 2009
  • 3 Answers
Good Morning -
Make sure the bulb is point in the right direction and don't use an incadescent? bulb like a 60 watt bulb.
make sure you use floodlightor spot light bulbs so theydon't shine on the sensor.
Have a Great Day!!
Posted on Jan 05, 2009
Why does my motion sensor light go on during the day? it is supposed to only turn on at night
Most likely the light sensor has stopped working. The light sensor creates voltage from light, like a small solar cell. If it quits producing voltage, the light system thinks it is dark.
Sep 28, 2017 | Cars & Trucks
I have set all the switches to the left TEST, Low sensitivity and Dual brite OFF and this light stays on all night??
putting the switches on test bypasses all the sensors leaving the light on all the time the test selection is only there to see if the light is working
Jan 15, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
Why did my motion light stop working and the sensor light is blinking red?
Did you find out why?? I just purchased 2 of these and loved them as they worked for like a week and now both are not working however they are getting power as the red light comes on when there is motion...Please help if you know as I paid 110.00 each for these and I am confused how the bulbs could be blown?
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Cooper ms34w wont turn off stays on night an day without movment
Have you had a look at the underside of the motion detector the should be some things for you to a just it with
Mar 25, 2014 | Cooper Lighting Flood Lights. 180 Degree...
I have motion sensor flood lights that are not turning on. I put it on test & it does turn on. But when switched over to 1, 5 or ten minutes it won't turn on. The red light on the sensor does turn
April, you didn't mention whether you did the test at night. In addition to motion sensing, the flood light also detects darkness before allowing the bulbs to light up. If it is night, check also that some other light source is not illuminating the sensor. If so, that could fool the sensor into thinking it is daytime.
Mar 03, 2014 | Electrical Supplies
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
Flood lights in back yard not working
Which kind of flood lights? Long time lighting during whole night or security lighting sensitive to people walking across.
If it is for long time lighting, you should select the fixture lighting source as compact fluorescent, led or small wattage HID lamps, this kind of fixture you do not have priority requirement for instant on, the following fixture is just for reference.
http://www.bulbspro.com/vista-10040-35w-hps-wall-fixture-w-photoelectric-eye-bronze.html
For security purpose, you need the flood light right away reach full brightness, normally you take following fixture with halogen bulbs.
http://www.bulbspro.com/vista-10031-motion-sensor-twin-light-control-kit-white.html
Nov 10, 2013 | Dishwashers
Motion sensor light not tripping off
If new, then it could be faulty. If old, then may have water damage.
POSSIBLE CAUSE
1. Light switch is turned off.
2. Flood lamp is loose or burned out.
3. Fuse is blown or circuit breaker is turned off.
4. Daylight turn-off is in effect.
5. Incorrect circuit wiring, if this is a new installation.
6. Light control aimed in wrong direction.
SOLUTION
1. Turn light switch on.
2. Check flood lamp and replace if burned out.
3. Replace fuse or turn circuit breaker on.
4. Recheck after dark.
5. Verify wiring is correct.
6. Re-aim light control to cover desired area.
Sep 04, 2011 | Heath Zenith Secure Home Motion Activated...
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Flood lights take a very long time to come on
Insure you are using a standard flood light on motion sensor lights and not a florescent energy efficient flood light as they take longer to reach full brightness as the bulb filiment warms up. They are better suited for constant lighting rather than intermittent purposes such as sensor lights.
Good Luck
Nov 21, 2008 | Heath Zenith Electrical Supplies
Electrical Supplies Logo
4,008 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
