Picture jumping my tv is a 32 inch panasonic. it started out with the picture jumping when you first turned it on. now it jumps all the time, and the screen goes black for a second. it is about 8 years old i think,
  • 5,568 Answers
If this jumping is accompanied by a sharp snapping sound, it may be the high voltage circuit discharging to chassis. Leakage can cause the jumping and a discharge can momentarily blank the picture.
If you want to try a 'cleaning cure,' I suggest you pull the plug (not just turn it off) for several hours, preferably overnight. Sets of this size can carry enough static charge to punch a hole through your thumb if you get careless.
Remove the rear housing (shouldn't be more than 6-8 screws) and using a clean paintbrush, and possibly a vacuum to **** up the dust, clean it well and pay special attention to the area around a largish misshapen black plastic object bigger than most anything else and connected to the back of the picture tube via a fairly thick cable.
Posted on Dec 09, 2008
Element flat screen 32 inch screen jumping and has green lines
I think if it was me I would return for exchange, refund or repair.
Dec 09, 2012 | Televison & Video
Jumping Screen
I've had a couple of these. The panel control board is going bad, but there may be a way to make it last a bit longer. If you go into the MENU of the TV, and turn off all the color correction, all the whistles and bells that come inside the tv to "make the picture better," it usually helps. Any kind of motion correction, or any kind of noise reduction (picture noise reduction) should be turned off. If the picture has a cloud of green pixels that seems to pepper the screen, then after you turn off all the stuff in the menu, unplug the TV for 5 minutes, and then plug back in. It should help the picture some.
Hope this helps...
Jan 05, 2009 | Insignia IS-LCDTV32 32 in. Television
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Hi, I have a Panasonic XF Series 31" TV, manufactured in Nov. 1994, Model CT31XF4OR. The TV randomly goes from a full screen picture to a single line, about 1/2 inch wide in the center of the...
Sounds like the picture tube is starting to go, I don't believe it would be worth repair or even if you can get the parts for a tv that is almost 15 years old, time to buy a new one.
Oct 09, 2008 | Panasonic Televison & Video
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV Problem
the red blinking light is a code that tells you what is wrong it will blink from 1 to 10 or just blinks all the time
Jan 03, 2008 | Sony KV-32S26 32" TV
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
