Question about Canon PowerShot A70 Digital Camera
Battery Indicator Flashing and then Camera Shut down
I have 4 new Energizer AA batteries in my Canon PowerShot A70. We have tested them and they are at full charge. The camera turns on, flashes the low battery symbol and then within a minute or two shuts down. I can sometimes shoot one or two pictures but this immediately causes it to shut down. 1. I have cleaned the battery terminals with Q-tips and rubbing alcohol. No help! 2. I have re-set the camera as per the manual instructions. No help! Can anyone out there help with this problem??? Thank you.
  • 1 more comment
  • Gary Meier Feb 26, 2007
    Canon website had firmware listed for the A70 but website did not have the firmware available (i.e. o.ogb) and there were no updates. Other advice please?
    Thanks
  • Gary Meier Feb 27, 2007
    Thank you for the responses. I have taken the camera to Canon Canada and they have indicated that if the problem is not a customer abuse problem that they will fix it for free and will FedEx the camera back to me at no cost. I was also told that although the Canon service dept is not a retailer I would be able to "trade-in" the camera on a new one - before it is repaired - and get a substantial discount on a new camera of my choice. That way Canon does not have to repair the old camera and keeps me as a Canon customer. Cost of repair not being done offsets discount on new camera. The street value of the camera I was interested in was $445.00 and they indicated they would sell it to me for $325.00. Interesting alternative!
  • whiskeyjay Nov 04, 2008
    (Change the Battery Pack"
    Several sets of fully charged batteries were tried. Terminals were cleaned. Everything was re-set once. And still the camera doesn't seem to be able to sense fully charged batteries.
    The camera will consistently power up when set in picture review mode. And 'sometimes' if you hold your mouth just right, it will power up and allow you to take pictures. But all the while in active mode, the low battery indicator is flashing.
    Does anyone have an address I can send this to?
    Thanks.
    Edward
I have the same problem on the same cammera. I sent it to canon and they say they will fix it for free. I have the same problem on a canon a530 and sent it to them also. My wife had droped that one and put a dent in the metal around the lense worked fine but they said they must fix it along with the battery problem at a cost of $108. Give them a call 1800 652 2666.
Posted on Feb 26, 2007
  • 72 Answers
Maybe reflash the firmware? Check Canon website for firmware update and instructions.
Posted on Feb 25, 2007
SOURCE:
I have a Canon PowerShot A590 digital camera. It
Hmmm. With this, I suggest looking through your settings and trying to find a "power saver" setting. If that doesn't work, you could report the problem to the company. They should switch out cameras if you still have your warranty.
Apr 27, 2010 | Canon PowerShot S2 IS Digital Camera
Just bought a second hand Canon Powershot SX100 IS.
Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
Mar 08, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
My Canon Powershot A2000 displays a low battery even when I've just replaced with new. I've replaced several times, each time with two identical batteries, each time from a different package. I may be able...
For the best results, I recommend you to use Canon rechargeable (NiMH) batteries. Rechargeable batteries provide the best performance and are the most economical choice.
Else......
AA alkaline batteries such as those from Energizer or Duracell will provide the best performance for non-rechargeable batteries.
Feb 11, 2010 | Canon Powershot A2000 IS Digital Camera
Camera has failed to operate giving a "change batteries" message
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 29, 2009 | Canon PowerShot S3 IS Digital Camera
A580 wont switch on with new correctly inserted batteries
Check for battery current ratings, Canon cameras need AA batteries with current rating above 1200 mAh, I use Energizer rechargeable batteries for my Canon Powershot SX110 IS. The batteries last more if we use the flash option wisely.
Jul 25, 2009 | Canon PowerShot A580 Digital Camera
Powershot SX100is battery life
hey, i had same problem.. after i started using energizer ultimate lithium AA it started lasting weeks
Jun 16, 2009 | Canon PowerShot SX100 IS Digital Camera
Energizer +AA NIMH Batteries consumed quickly
There are many grades of batteries under the same manufacturers name. They have a different Ah rating. The lower the Ah the shorter the time they will last.
Mar 02, 2017 | Energizer Duo Battery Charger for AA and...
CANON POWERSHOT A530 LOW BATTERY READING
Alicia,
Mentioned on my blog that the last paragraph of the advisory states:
""PowerShot A530 and A540 digital cameras affected by this phenomenon will be repaired free of charge, regardless of warranty status. Accordingly, if the opening/closing spring on the inside of the battery cover of your PowerShot A530 or A540 digital camera sticks out, please do not use the camera. Instead, please contact a Canon call center (1-800-OK-CANON) at your earliest convenience."
But also mentioned that if they don't help, a temporary fix is to insulate the spring from the battery contact plate. Merely place a small piece of tape between the portion of spring that's sticking out and the metal battery contact plate.
Sep 09, 2008 | Canon PowerShot A530 Digital Camera
Canon A460 problem
I have a Canon A460 and the only red light I know of is the auto-focus light. If it's a low battery you'll see the indicator on the screen, not a light.
Aug 11, 2008 | Canon PowerShot A460 Digital Camera
Battery getting exhanusted
Sounds like you need to call Canon. I use Energizer e2 batteries and take 700 pictures and several videos during a show I attend and still have battery life. Even with normal batteries you should be able to take several hundred pictures. Are you still under warranty?
Oct 23, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A70 Digital Camera Logo
134 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
