Question about Nu Mark Numark Cdx Table Top CD Player CD Player
Disc Drive is acting REAL SHADY!
I was spinning at the club last Friday and my damn CDX would not read my disc after half way through my set (2 hours in). This happened on just one. Initially, the CDX would not even accept the disc...just popped it out. Then after it took it, the display would read either "CD OUT" or "NO DISC." The only solution was turning it off and back on...
Seemed to work.
My question for you all is a three parter:
1: Does anyone think that cold weather could be a contributor to this? I live in Bend Oregon (6 months of the year it is damn near freezing) and store my equipment in the garage.
2: Does anyone think that not storing these flat could be a contributor? I keep them in their coffins and they sit up on end. The coffins are obviously heavily padded so they cannot move around once they are locked in, but sitting in an orientation for sometimes days at a time.
3: Have the updates helped anyone...seriously?
  • funkem Apr 26, 2009
    i am starting to have the same problem with mine!
    i live in sydney australia and i haven't even had them for a winter here yet so its not the cold.
    And mine just sits at home flat i never take them anywhere!
    So its not storing them on an angle that will make them do it.
Its an heat issue,the only way heat can release from these is from the bottom.heat rises so its hard for it to excape .so the power supply heats up and voltage begans to drop causing weird things.try cooling fans,worked for me.
Posted on May 05, 2009
  • 68 Answers
Possible servo problem..
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
I load a dvd in the sylvania sdvd 9009 player and it says no disc after loading
If the DVD loads, there should be something on the display that indicates it is being read (maybe a spinning disc icon). If it tries to read, then displays the "no disc" icon it means either that particular DVD can't be read or the drive has failed. If you try another DVD and get the same result, you can be pretty sure the drive has failed
Dec 16, 2012 | Televison & Video
JE530 c13
1) It's more likely your laser died than the the drive failed.
2) Run back to your repair guy, and when they fix it (IF they fix it), ask to see it work before you go home. They damned well better fix it for free!
3) Buy another one on eBay.
C13 means the machine cannot read the TOC on the disc. It is possible you have a disc with a bad TOC. You may have left it near a magnetic field, such as a speaker or a component transformer. Try another disc. Or take a disc and erase it, then record on it. See what happens.
Sep 18, 2012 | Sony MDS-JE480 Mini Disc Player
Half an hour ago the player was still working fine. Now it's impossible to eject cd's and the player itself gets confused cause the cue goes on and off by itself and playback skips. HELP
The CD drive in your CDJ is hunting for the disc, i.e it has become difficult for the player to read the disc. Keep your ears next to the loading slot after inserting a CD, you will hear a motor spin up then slow down then spin up again and if this continues the system will lock out the eject function. Or else the disc will come flying out!!. Either you need lens cleaning ( try a cleaning kit ) or replacement ( If the player has crossed over 500 hours of use )
Mar 09, 2011 | Pioneer CDJ-100S CD Player
"No Disc" error message
A no disc error on any electronics device indicates one of three problems. 1. The disc reading lens in the cd/dvd/brd drive has gone out or is dirty. 2. The drive has a "stabilizing" screw that must be tweaked. 3. The disc is not spinning due to a bad motor on the drive or something is blocking it. If you can hear the disc spinning *whizzing sound* its not a motor issue. You can try running a cd lens cleaning disc but if its not registering it probably wont spin, thus wont clean the lens. You can attempt to clean a lens with a cotton Q tip and rubbing alcohol but be warned, touching the lens can scratch it and destroy it. If your object is not under warranty you can have a professional look at the drive to check the tension on screws, this is usually a huge problem found in XBOX 360's. Make sure its not the disc by trying other working games/movies/etc. If all else fails you can always purchase a new dvd/cd/blu ray drive and have it professionally installed. Xbox 360 $20-$40, PS3 $100-$150 Although its not common, another solution is that cables on the drive might be loose, but usually you cannot open the device; the two cables are power approx. 1-1.5 inches long and the output plug which is usually half the size.
Jan 09, 2011 | Video Game Consoles & Games
PS3 Blu Ray Drive Not Reading Or Spinning Disc
Check your cables. Try swapping lasers with a friend. Those are the first things I would try.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
Compaq Presario C300 DVD Driver Problem
i think the problem is with the lense.
probably the lense has gone.
try the cleaner Disc it might help.
plz do rate this problem so i can help others. :)
Jan 28, 2009 | Compaq Creative Sound Blaster PCI 128...
Can't figure out how to change the time
Press DSPL for 2 seconds
Press the + or - volume buttons to set the hour
press SEL
Use the volume buttons to set the minute
Press DSPL
Jan 05, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
Disc Jumping
I used to have the same problem: the rubber feet of the players are too stiff. It is indeed vibration that causes the problem. Btw: after a couple hours in a club, you are usually playing much louder than at home, with more low-end punch.
I haven't had a single problem AFTER systematically setting the players on foam. This is similar to the tennis balls trick for regular turntables, except that here you need something a softer suspension as the players are very light. Shipping foam is good; camping foam mattress works also.
Jul 14, 2008 | Vestax CDX-05 Turntable
Xbox not reading disc properly.
This could mean your disc is corrupt, or something is wrong with your drives lense. Call XBOX customer support and they'll help you fix it. 1-800-4MY-XBOX
Jan 11, 2008 | Microsoft Xbox 360 Console
CDPops Out *EDITED*
Does it pop out immediately? If not, listen carefully to the drive after you insert the disc. Can you hear the disc spinning? Any activity from the laser? If the disc is not spinning but you can hear the faint whirring and clicking of the laser transport, it could be that the laser itself has failed - it's the laser that detects if a CD is present. If it doesn't detect anything (due to being knackered!), the disc will not spin and will eject.
Oct 31, 2006 | Nu Mark Numark Cdx Table Top CD Player CD...
Nu Mark Numark Cdx Table Top CD Player CD Player Logo
511 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
