Question about Dryers
Ge dryer mod # dde7500velwh getting power but not turning just makes noise when started
IFIXALL
  • 868 Answers
SOURCE: ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
Posted on May 21, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Dryer making buzzing noise
It does not look like there is an access panel from the back side on this model, but you may be able to try this: Remove power to dryer. Take screw out that holds the end of the exhaust pipe to the back of the dryer and pull out the metal exhaust pipe. Now you should be able to look in and see the end of the motor and the belt. Release the belt and turn the motor shaft by hand. If it turns easily, the drum supports slides are pobably shot ( WE1M333) and possibly the part that holds them (
WE3M26) which causes exsessive drag on the drum. If the motor shaft does not turn easily, hope you have a sock or wash rag stuck in the blower wheel. If not, motor is bad. To get at the blower or the other parts you will have to take the screws out holding the top down to the front of the dryer, then remove the screw on each side near the top holding the front on. Lift the front slightly and remove. You don't have to take off the wires to the door switch. Parts I listed are supporting the drum on the top side. If you need more info do an "ask me" question.
Posted on Sep 03, 2008
MNTECH
  • 1543 Answers
SOURCE: dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Posted on Nov 18, 2008
SOURCE: whirlpool dryer
sounds like stuck brushes in the motor (bad motor)
Posted on Dec 17, 2008
dragonsthatk
  • 547 Answers
SOURCE: GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
Posted on May 17, 2009
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
Why does my GE 7 Cycle Dryer makes noise when I turn the start button, but does not run the dryer
The start button just engages it to run. See if the wires are still on it. Turn off your breaker, then back on. If still not working, then replace starter switch.
Mar 12, 2013 | Dryers
My Maytag Dryer won't start. Mod.# MDE3000AYW . The on button makes the right noise like it is going to start but nothing happens. Sometimes I get lucky and it will start but most of the time it just...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 05, 2011 | Dryers
The Dryer will not start but has power as the drum light works.rhe start switch seems to have power going to it but makes no noise when turned to the right and dryer does not start
heatman101
Nov 08, 2010 | GE DBXR463EDWW Electric Dryer
My GE dryer makes a power noise but it does not turn on. What should I do?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Aug 28, 2010 | GE Dryers
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
142 people viewed this question
Top Dryers Experts
