Question about Dacor Preference PGR30SS Gas Kitchen Range
Viking ignitors when i turn the knobs i ignite the stove all ignitors turn on and stays on no matter what power i turn the knob at unless i turn the knob off . please help
  • 2 more comments
  • antonioambar Dec 09, 2008
    the ignitor keeps on clicking unless i turn the knobs o the off position.
    i have a viking stovetop with six burners i should have been more specific i'm sorry.
    i does no matter witch knob i turn all six ignitor start clicking and stays on unless i turn the knob on the off position.
    when i turn the any knob all six igniters start clicking and they stay on unless i turn the knob to off position.
    Sergeant:
    Champion:
  • 283 Answers
Hi, please dont rate me yet if this could not fix your problem. Check well the igniter, remove the knob and try to clean it with wd-40. If doest work need to replace the igniter. Thank you.....
Posted on Dec 09, 2008
  • 1,800 Answers
Clen th knob there is a short circuit caused by humidty just clean th under of th knob and every thing is gonna be alright.
    Genius:
  • 1,199 Answers
The igniter is stuck ...spray switch with areosol lub push in and out with fingersand then try it again
  • 4,806 Answers
Please be more specific for example gas flame stays the same or the ignitor just keeps on clicking
kind regards
  • Lee Hodgson
    Lee Hodgson Dec 09, 2008
    Ok.disconnect from the mains for 10 mins or so, if you have a can of WD-40 handy spray the ignition switch with it and depress it a few times to release it as it sounds like its stuck on
    post back with the results please
    regards
  • Lee Hodgson
    yes the ignitor is stuck on, use WD-40 to release it as i mentioned above
    regards
I have a GE Hotpoint stove/range model num 317B6641P001 that the oven will not ignite nor will the igniter turn on.
It sounds like the ignitor is bad...you will not or should not smell gas if ignitor is bad...gas valve is not supposed to open until the sensor by the ignitor has reached a certain temp. It's a safety feature. If you replace the ignitor, it should work like normal.
Jan 31, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
I have a Viking vgic365-4G gas range. I recently replaced the spark module, the ignitors for the oven and the griddle, and the spark ignitors for the burners. The problem I am having is only one of the...
their is one of two things causing that,
1) the switch that supplies power to the spark module when the burner is turned on is bad...its located on the shaft of the burner valve thier is one switch for each knob so counting the oven and the burners their is 5 (the oven is different from the surface burners) to check those switches what needs to be done is remove the knobs then the face panel so ya can get to the knobs.
No is where is gets a bit complcated if ya dont follow all procedures....the knob must turned on to check so gas will be flowing and ya must light the gas using a match or raw gas will eneter the kitchen...or if possible temporarly turn off gas supply to the unit.also POWER MUST BE DISCONNECTED and then with power off and the burner lit manually once turned on ya would need to check each switch to have continuity,if any of the switches does not have continuity when measured with a ohm meter that switch will be bad
2) the igniter is cracked so power is coming from spark module yet since its cracked power is jumping out before it gets the where it lights the burners.
GENE
Oct 02, 2011 | Viking VGIC365-4G Gas Range
I have a gas Viking range. The oven burner ignitors light up and ignite the gas burners but quickly shut off - then go on again and off again- intermittently but frequently. This does not permit the...
Here is a test you can use to check the ignitors, Ignitor test. I also would like to you turn the thermostat knob slowly from the off position, When do you hear the click in the knob? You should hear it before the warm or lowest numbered setting on the knob. If you don't, replace the thermostat as it has failed. Need full model number to get you part.
Good Luck
Stay dry out there!!
Aug 28, 2011 | Microwave Ovens
How do you access the ignitor wires for the
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range.
Apr 08, 2010 | Viking VGIC485-6G Gas Kitchen Range
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
My 2 year old sons played "drummer boy" on the knobs of the Viving Designer Series cooktop and now they will not turn. 2 of the 4 popped back and work but the other 2 did not. Tried turning them but no...
they must be bent....look around the knob make sure you have an equal amount of space betwween knob and stove...if not, try to carefully bend it until the knob straightens up....
Nov 08, 2009 | Viking 31 in. DGSU100-4BSS-LP Gas Cooktop
Spark ignitors won't stop sparking Kitchenaid KDDT2078WH
I hope that you have unplugged the range from the wall... Until this is resolved, you need to remove power from the stove. Use a lighter (long nose type is best) until this is corrected.
To identify the exact cause, you will need to expose (one at a time is ok) each of the contacts assoicated with the burner control knobs.
Each burner control knob has a setting (ignite) that closes a set of relay contacts and allows the igniter transformer to fire all of the spark-gap igniters. Since they all "spark" from any knob, you must isolate the knob that has the short circuit in it.
So do the following: (WITH THE POWER PLUG REMOVED FROM THE WALL....)
1. Expose the back side of a knob.
2. locate the press on wire on that knob.
3. Remove that wire from the know and place it on a piece of paper toweling (to isolate it from any metal).
4. Plug the stove into the wall and listen for sparking.
5. If NO sparking is heard, you have located the bad knob. If spark IS heard, unplug the stove and restore the wire. Move onto the next knob.
6. Repeat steps 1 - 5 until the spark does no appear.
7. Repair or replace that faulty knob assembly.
Let us know of your success.
-Jim
Oct 18, 2009 | Kitchen Ranges
3 out of 4 stove ignitor not working
sounds like you could have an igniter problem,also i noticed my stove does that after i clean it,i was getting the igniters wet,had to just turn the burner on and light it with a lighter and leave it on till the igniter dried out.
Jul 18, 2009 | Kitchen Ranges
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Dacor Preference PGR30SS Gas Kitchen Range Logo
56 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
