FixYa.com
Tags:
Ubi Soft Catz 5   for PC
Petz5 won't play or uninstall Plz help!! (by 5 users)
posted by cries on Feb 24, 2007
Well, I just downloaded Dogz5 to go with my Catz5. i one day tried to open my game it said, "Please insert correct disk, press OK and restart the application." So I opened the disk drive, my game was in there. I tried to uninstall my game, but when ever I try, I have to wait a long time, then the screen turns white. I click Ctrl Alt Delete and it says that my Petz5 setup is not responding, so I have to exit the program. I tried a thousand times and I still have no solution. Help would be appreciated!
Comment by cries, posted on Feb 25, 2007
I really found out what was wrong. Something is wrong with my cd/dvd player on my computer and it won't show up on my computer. So I am in trouble! If my computer gets recked I'm going to have to sacrifice my tent money for the summer....
Comment by cries, posted on Feb 26, 2007
Don't worry. I can get it repaired if I want to. I got about 100$$ in my account and will save up for future repairs. It's my computer and my responsibility. I am scared to do this by myself because I might ruin the computer again. My dad will fix it. Don't worry.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Torchwood, posted on Jan 07, 2008
I loaded both catz and dogz 5 onto my computer, but now they wont play. It says that "petz5 has encountered a problem and needs to close.
I have tried to uninstall it but I have to wait a long time, then the screen just goes white. HELP!! This is on my main computer, but on my laptop, the game works fine. I think I caused the problem by forwarding the date on my computer, to make the game go faster, them putting the date back. That would confuse the game.
Is there an easier way to uninstall the game? and can I fix the problem?
Comment by NiokiNiki, posted on Dec 28, 2007
Yeah, it's the same for me as well. I already downloaded Catz 5 and burned the CD, but after I installed it, it doesn't want to play and the same message, 'Please insert the correct CD-ROM, press okay and restart the application'.
It's incredibly annoying and I've already tried most of the solutions below like cleaning the CD and burning it as an image file. I can't use the download website because I have to pay. I really need help because I miss this game so much and I've wanted to play it for a long time. T_T
Comment by Guest, posted on Nov 09, 2007
hi i try to play petz5 on my computer but it says it is an illegal operation but it's not i dont have money to fix it could you fix it for free?
Hi when I click on Petz5 it says that it is an illegal operation but it worked before I really want to fix it but I dont know how do I have to put the disk in or something?
Best Solution
Thanks for Trying (70)
Noggin
Rank:Guru Guru
Rating: 87%, 1463 votes
First check if the cd is dirty, scratched or damaged. If this is the case then you can try polishing the scratches out with a soft cloth and liquid metal polish (only polish the side away from the foil/label and try to only polish the scratched area) don't worry about removing scratches completely - start with the worst, then try the disk again - it might just work.
If this doesn't help then try the disk in another machine or another disk drive. if it now seems to work then although your drive may seem to work on other things it is probably getting tired.
I am assuming that you purchased the game and have a legal copy. If not then that is likely to be the problem as the software protection will not allow you to play the game without the correct CD. If you downloaded the file for the Dogz part, try burning it to CD as an image file (Check your burning software for details) and try running the game with that in the drive.
If that doesn't work, then you are able to disable the CD protection file yourself if you have purchased the game so you don't have to have a CD in each time you want to play.
go to:
http://www.ddlsite.com/dogz/crack-serial...
and search for dogz or petz and download the appropriate crack for your version.
find the install directory where the game is installed(usually c:\program files\ubisoft\petz) and then copy the crack into this directory, and say yes when it asks if you wish to replace the slightly larger file - now the game should work.
Please ask for more details if you are unsure how to proceed with this and I am happy to oblige.
Comment by Noggin, posted on Feb 26, 2007
Please let me know the model number /manufacturer of the drive and I may be able to help - If you don't know this then see if you can find it in the device manager (in widows XP right-click on my computer, click properties, then click device manager there should be a listing under DVD/CD rom drives. If not, unplug your machine, take the cover off and see if you can see the manufacturers label on the drive without removing it.
If you have to remove it, you can usually do this without disconnecting the drive - there will be up to 3 screws each side of the drive holding it to the frame - remove them and gently slide the drive in or out (depending how long the cables are). read the label and write down everything then put the drive back and replace the screws. If you need to disconnect the cables, then method will depend upon which model you have, however usually gently pulling directly away from the drive should do this. Cables must ALL be connected back before restarting the machine - most will only go back in one way and shouldn't be too hard to insert. If you can do this procedure then you can save yourself a fortune, buy a new cd/dvd drive (around $50 will get a good one) and you can fit it yourself.
Let me know if you need more help.
P.S. if you have been trying to use a program called Daemon Tools or Alcohol or sd4hide or similar copy protection or virtual drive programs then this may be the cause and your drive may be fine - uninstall these programs, see if your drive is back after a restart. If you want to use these utilities safely then read the instructions to avoid the same happening again.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 15, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
ok my game is not working well it was intill i downlaoded cats 5
Can you Help with these Education and Reference Software problems?
Ubi Soft Catz 5 (Windows) (680901) for PC
Missing Toys and South Seas...
I have played Catz for a few... Answer This...
help me instol brothers in arms...
i need help to instol brothes... Answer This...
HELP
HELP! ITS ME EBVOGEL. HELP... Answer This...
Help
my petz 5 game won't work it... Answer This...
HELP!
i have the right system i need... Answer This...
Repair Service
Find Education and Ref. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
