Question about MGI Software VideoWave 4 for PC
Good Evening: Do you have and where can I find a driver to run USB VideoBus II and PhotoSuite III se on my vista OS. Error shows up that I require a current Indeo codec. Thank you very much. Phil Pate
    Scholar:
  • 91 Answers
Try the link below:
http://www.moviecodec.com/downloads/31d.html
Let me know if this is the codec you are looking for. Thank you, Binary Bob
Posted on Dec 09, 2008
I have problem to jvc cam.And i have installed all drivers (MGI photo III se) and twain driver but the problem is that the camera doesnot connect to pc.There an error comes that connection...
'MGI photo III se' is, I believe, software, not a driver as such. Are you sure that the drivers you have installed are compatible with your OS?
Aug 09, 2017 | JVC GC-A33 Digital Camera
Driver for Pretec DC-300 Digital Camera for Windows Vista
Try this:
Uninstall the driver (if installed). Next, put in the driver CD and browse to the setup.exe file. Right click and select properties. In the box that opens, select compatibilty tab and select the box next to "runthis program in compatibilty mode for" and select XP SP2. and install the program
Should that not work, uninstall and retry the above process, but select Windows 98 or 2000 this time..Hopefully that will work.
If it still does not work, then unfortunately, you will either have to downgrade to XP (I believe the driver works for XP) or buy a new camera altogether..
Jun 04, 2008 | Pretec CompactCamera Digital Camera
I have replaced my xp computer with one running Vista. Will the Visioneer 6600 scanner work with Vista?
The 48-bit color Visioneer OneTouch 6600 USB scanner delivers outstanding image quality by recognizing over 281 trillion colors at 600x1200 dpi optical resolution. The scanner has three convenient buttons that integrate with the ScanSoft PaperPort Deluxe software to make emailing, copying, and storing images and text effortless. The software bundle also includes ScanSoft TextBridge Pro OCR and MGI PhotoSuite III SE.
The scanner driver is certified by Microsoft for Windows XP, and also is compatible with Windows 98, Windows 2000 and Windows Millennium Edition.
It is not compatible with windows Vista.
Apr 25, 2010 | Office Equipment & Supplies
How can I run Caesar II on windows vista
You can run it on vista, though you need a DOS emulator, for which i recommend DOSBOX.
download this, make sure you have a folder for all your caesar II files in your C: directory and call it caesar2, then run dosbox
once it is running type in this order in dosbox:
mount c c:\caesar2
c:
call c2
a new page will come up and tell you its not a valid drive, choose the second option in the list by pressing spacebar. caesar II should then start running
Jul 08, 2009 | Sierra Online, Inc. Caesar II for Windows,...
Won't work with windows Vista
right click on belkin , click on properties , click on compatibility tab
tick box , highlight the vista line , click apply click ok
that brings belkin into line with vista
May 08, 2017 | Belkin VideoBus II Video Capture
Running MGI Photosuite version 8.05 in Vista
MGI Photosuite on Vista, THE FINAL SOLUTION!!! First you need to get hold of an MGI disc or a download. I have been trying to get MGI Photosuite III SE to install on Vista for months without success and then when I thought I'd finally sorted it I could not launch the program due to a script error. You do not need Virtual PC, Virtual XP or any add-ons. Simply find and right click the the MGI setup file, check the run in compatibility mode as Windows XP SP2 and install. After install, send a program launch shortcut to your desktop, right click, go to properties and check the Windows XP compatibility mode once again. Finally, while you still have the compatibility screen open add a tick check to Run As Administrator. Hey presto my beloved MGI Photosuite is back! MGI is fantastic for being user friendly and simple, and although I know other users insist there are better programs, I’ve tried loads and I still think it’s a winner.
Mar 25, 2009 | Computers & Internet
Maxtor one touch II
This doesn't require downloading anything, installing anything, or holding your mouth in a certain way.
1) Plug the drive into power and into your Vista PC's USB port.
2) When the 'Found New Hardware' wizard pops up, click the recommended option. When it says it can't find the drivers, select 'Show me other options', and then Browse your computer for drivers. Choose the C:\ drive, and click next.**
**The key here is that Windows Vista comes pre-installed with the drivers for the Maxtor external hard drives. So they're on your PC, even if the Wizard tells you they're not.
4) Wait a few minutes, and yo will see a window that reads, "The software for this device has been successfully installed," and now it will appear as a drive letter under 'Computer'.
thanks RP
Aug 18, 2008 | Maxtor OneTouch II 300 GB Hard Drive
Incompatible Driver(s)
I would uninstall Photosuite.
I don't think that Roxio is supporting that program anymore. I have version 7.0 and it does some goofy things in Windows XP they never fixed in the slide show mode.
Jun 10, 2008 | Roxio PHOTOSUITE 5 PLATINUM CD for PC
Driver
Download and install adobe reader for manual, if needed
use Get Adobe Reader button on this page
http://www.adobe.com
Manual link (two choose based on directions)
http://www.bushnell.com/customer_service/manuals/binoculars.cfm
There may be no driver required for vista for the USB access to the camera.
However one of the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
This Vista support link may help
http://kb.roxio.com/content/kb/General%20Information/000004GN
This Update is PhotoSuite Version Specific, you will need to find the version of PhotoSuite installed on your system before selecting the update.
To find the version of PhotoSuite that you have installed first open PhotoSuite and then Go To "Help" and then to "About Roxio PhotoSuite", once the About box opens you will find the version at the bottom center.
If you have version 5.1.2529.0 or higher this update is not needed.
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1366.0 only.
Note: The latest Easy CD & DVD Creator Engine update should have already been installed.
(This update will take 5 to 20 minutes to install, there is no progress bar, so you should not interrupt it.)
Download
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1419.0 only.
Download
Update PhotoSuite 7 Platinum to 7.0.430.0 (English Only)
Important Note:
This updater is intended only for the stand alone version of Roxio PhotoSuite 7 Platinum. If your version of PhotoSuite 7 was included with Easy Media Creator 7 then please (use those listed above) for the correct updater.
Download
Dec 22, 2007 | Bushnell ImageView 11-8200 Binocular
Driver
Manual link (two but these appear to be the same)
However the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
Download
Download
Important Note:
Download
Dec 22, 2007 | Bushnell ImageView 11-8321 Binocular
MGI Software VideoWave 4 for PC Logo
140 people viewed this question
Top MGI Software Computers & Internet Experts
bandman1967
bandman1967
Level 1 Expert
Rommel Balcita
Chris Braid
Level 1 Expert
Are you a MGI Software Computer and Internet Expert? Answer questions, earn points and help others
