Question about Hotpoint HSS25GFP Side by Side Refrigerator
Ice Sheet on floor of freezer
Freezer seems to work fine but we continually have a build up of water that turns to ice on the bottom of the freezer and the little shelf behind the bottom drawer.
  • Anonymous Mar 18, 2014
    was told there is a design flaw behind freezer panel, too narrow space ice builds up
  • 247 Answers
Check nothing is holding the door ajar, and that the door seals are closing properly all the way round. The abnormal thing about abnormal ice buildup isn't the fact that it's frozen - it's the fact that the water is getting in. The only way water is going to get in without you noticing it is in the form of moist air - and the biggest, most regularly disturbed way in for moist air is the door and its seal. A.
Posted on Feb 24, 2007
Ice forming on bottom of freezer with water leaking out from under
I'm guessing the drain from the freezer defrost pan (below the freezer coil) is clogged and overflowing into the bottom of the box. You'll have to turn off an defrost the freezer, then remove the sheet metal on the back to expose the coil. Try pouring some water into the drain pan and if it backs up, use a fine wire like a sewer snake to clean it out.
Feb 28, 2018 | Maytag MBF2256H Bottom Freezer...
LG LFC21760ST: In freezer area floor, there is ice build-up. Water is leaking from the back wall where two horizontal openings are (near the center). We've turned off the water for the ice maker but this...
If you shut off the water to the ice maker, the only other cause is a plugged drain hole. Somewhere around the bottom of your freezer there will be a small hole that allows moisture to drain out of the freezer and into a catch pan under the refrigerator. If this hole is plugged with ice then the water has no where to drain but out the door of the freezer and puddling on your floor. The water you see dripping is condensation that has built up in the freezer itself.
To fix this problem, you need to dislodge/remove the ice from the bottom of the freezer and the hole. I have had the best luck using warm water with a turkey baster. Another alternative would be an ice pick or any type of utensil that can be safely used to dislodge the ice from the whole and the bottom of the freezer. I prefer the water method because it is the safest. Ideally what you want to do is force warm water in small quantites down the hole. This will melt the ice and reopen the drainage. You then need to remove any ice around the bottom of the freezer using warm water. When done make sure to dry the bottom of the freezer.
May 05, 2011 | Refrigerators
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Ice build up on the bottom of freezer
Check to see if after clearing out the ice sheet, that the gasket for the door is tight against the freezer. If air is leaking by the gasket, it will build up really quick.
Jul 09, 2009 | Kenmore Refrigerators
Ice build up on freezer floor.
Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
Thanks
Vic
May 22, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Apr 09, 2009 | GE Monogram ZICS360NR Bottom Freezer...
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Ice build up on the bottom floor of the freezer
Sounds llik a defrost heater is open if you
have a VOM you can test it for continuity
Its probably behind a panel in the rear bottom
of the refrilgerator Should have a pan under
there to
Nov 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom of freezer icing with thick sheet of ice
you have a froen drain thats why it is allways getting ice on the floor. you need to remove as much as you can then remove the back of the freezer so you can clear the drain pan and clear the drain. its not hard to do just you will have a lot of water on the bottom and your floor maybe. once you remove the ice from the pan have some very hot water and pour it in the pan utill the drain is free and the water go's down into the drip pan. shut the unit off untill tour done and be carefull around the coils. once its clear put the back on and plug the fridge back in. you will now have no more ice build up. make sure there is no food back there that can block the drain either. its a god time to clean the freezer out
Aug 10, 2007 | Zanussi ZEBF250W Bottom Freezer...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
237 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
