Question about Dell Inspiron 9300 PC Notebook
Removing CD drive on dell inspiron 9300
Can you please tell me how to remove/replace the CD drive? I believe mine has gone bad and before ordering a new one, I want to make sure I know how to replace the part.
Thanks so much!!
  • Dell Master
  • 4,806 Answers
While the PC is on eject the DVD tray and turn off the computer, underneath the laptop you should find a screw which is holding it in place, when you find the correct screw and unscrewed it pull gently on the DVD and it should slide out, put your new one in and replace the screw, job done :)
regards an please don't forget to rate us
Posted on Dec 09, 2008
Seven beeps on inspiron 9300 no screen how to fix?
the beeps are a code to tell a technician what has gone wrong
take it to a repair shop and have the problem diagnosed and get a quote .
Sep 19, 2015 | Dell Inspiron 9300 PC Notebook
I have removed the ram, hard drive and cd rom but it does not work hp nx6000
If after removing those, it still doesn't POST, then there is a motherboard fault. Consult an authorised dealer.
Feb 12, 2011 | Dell Inspiron 9300 Notebook
My dell inspiron does not start up
does the bios start? if so get into the bios and tell it to start from the appropriate drive, which is the hard drive, not the cd rom, if that wont start it then you may have a bad hdd
Sep 18, 2010 | Dell Inspiron 9300 PC Notebook
What is the cost of "dell inspiron 1525" laptop lcd
This one isn't too bad. The lcd for this labtop can be found on ebay.com for 69.99 to 150.00.
its pretty inexpensive. The hard part will be putting the lcd in. If you have not taken apart electronics before it can be pretty hard to do. You have to basicley remove the keyboard, remove the screws that hold the LCD on, then you have to remove the lcd rails. and then re-install the components. If it is just the blacklight that has gone out this can be easier or harder and i usually recommend replacing the whole lcd if its that inexpensive. I hope this helps out
Thanks
Steven.
P.S. just search on ebay for "Dell Inspiron 1525 lcd"
Apr 29, 2010 | Dell Inspiron 9300 PC Notebook
Dell inspiron screen went black when i booted up the system
check it with external monitor if you get display then lcd is gone bad otherwise if you get dell logo then restart the system , press Fn key and power on the button it will start psa test
check for any hardware failures.
if hardware is working fine hen you will have to reset the system back to factory settings or reinstall fresh operating system.
Mar 06, 2010 | Dell Inspiron 2200/6000/9200/9300 8x DVDRW...
My dell inspiron 9300 reads and plays DVDs, but does not detect any other type of CD in the CD/DVD drive (music, data, etc.). i've had a problem before where it didn't read CDs or DVDs and it turned out to...
Go to the support.dell.com webpage, enter the service tag number, located on a label on the bottom of the laptop, and download the latest BIOS update and drivers for the CD/DVD drive. You can verify the drive type in Device Manager. Once you have downloaded the files, upgrade the BIOS, this will restart the system. Next, remove the CD\DVD in Device Manager and then install the new driver for the drive. When the driver has been installed, Open Device Manager and right click on My Computer at the top of the list and left click on Scan for changes. The drive will be detected adn installed with the new driver and the registry will be updated.
Good luck, and please let me know how it works for you.
~Spoem
Dec 14, 2009 | Dell Inspiron 9300 PC Notebook
DELL INSPIRON 1525 not recognizing CDROM Drive
  1. ensure drive is recognized by the BIOS (It should be ID'd by model in BIOS
  2. If drive is seen normally in bios, then try the fixit utility in this link: http://support.microsoft.com/kb/314060
  3. See if you can boot to the drive using your Vista DVD and run a repair my computer from DVD
  4. If none of the above works, replace the drive. If system will boot to DVD, then reinstall Vista
Sep 29, 2009 | Dell Inspiron 1525 Notebook
Power light comes on and goes off and machine is dead
The Motherboard is bad but before you buy one.Try this Remove the memory, cd rom,hard drive battery, power adapter. Press and hold the power button down for about twenty .Replace the memory only,power up if you get the same result the motherboard has to be replace
Sep 15, 2009 | Dell Inspiron 9300 Notebook
My inspiron 1501 will not turn on
Hi
Please follow these steps.
http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/index.htm
Here is the service manual. Follow the steps in this and let me know what exactly happens.
These are the devices you need to remove by using the manual. the instructions are given in the manual.
first before you remove any parts
try to run a diags by pressing Fn+power button together and turn on the laptop.
Fn found on the lower right of the keyboard.
1.Hard drive.
2.CD Drive.
there are 2 memory cards and 2 memory slots in this laptop.
Remove both of them.
try each card in each slot and make sure that there is only 1 memory card in the system at a time.
Post your results.
also post what are the lights that are on.
check num lock, capslock and scroll lock lights and post the results
I can tell you if any parts have gone bad and if gone bad how you can buy and easily replace those.
thank you
Rakesh
Dell Laptop Expert
Jan 07, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 9300 lights up for 5 sec.it turns off
If the battery is fuly charged and the power supply is functional, my experience has been that the system board has gone bad.
Dec 30, 2008 | Dell Inspiron 9300 Notebook
Dell Inspiron 9300 PC Notebook Logo
112 people viewed this question
Alun Cox
