Question about Simplicity Serge Pro SW432 Mechanical Sewing Machine
I need help
I just need instructions on how to work my serge sewing machine
because i misplaced mines when i moved
  • Simplicity Master
  • 5,568 Answers
If you just need the manual, you can download it here:
Simplicity manual
Posted on Dec 09, 2008
I need a manual for a Serge Mate 4350D
Babylock Model 4350 D Serge Mate Instruction Manual
www.sewingmachinemanual.net/...Manuals/.../Babylock_4350-D_instruc...
Babylock 4350 D Serge Mate Instruction Manual. Contains 20 pages of information on how to thread, maintain, and operate the machine. This manual is ...
Where Can I Get A Free Instruction Manual For Sergemate ...
arts-literature.blurtit.com/.../where-can-i-get-a-free-instruction-manual-fo...
Answer (1 of 1): Www.simplicitysewing.com and go to downloads... I was able to download same manual in a matter of minutes.... Good luck.
Nov 05, 2015 | Sewing Machines
Where can I get a book to show me what it does?
SERGER:
A serger can do a lot of things. Frequently, they are used to finish raw seams and hems, but there's so much more they can do. It's mostly just a matter of experimenting and deciding how to apply it to your projects. I've even serged a strip quilt.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjLr5jft4fNAhUVK1IKHUJ1DkQQFggdMAA&url=http%3A%2F%2Fwww.peggyddesigns.com%2Fpdf%2Fyou_did_that_with_your_serger.pdf&usg=AFQjCNE3-5sHx4gwgk640NyspfXivuYzkw
You can download workbooks and work through them. (This is a Bernina work book site, but sergers frequently can do similar stitches.)
My BERNINA Workbooks
Sewing 201 Do need Serger
Serging Projects and Designs
Aug 18, 2015 | Baby Lock Sewing Machines
I have a babylock evolve serger. It serges fine w/o the blade engaged. Once I engage the blade, the stitches don't hit the fabric
most Sergers have a blade adjustment that allows you to move the blade closer to the sewing plate as well as further away sounds like yours may be to close to plate. Open the door to the underside of your sewing machine; their should be a round knob at the base of the blade are. Turn the blade until it moves away from the sewing plate. test and see if you have adjusted it enough so as not to cut your stitching off. hope this helps
Jan 11, 2015 | Sewing Machines
Need manual for Easy Lock 804 serger
Mine was destroyed in the floods a few weeks ago and I found a download and printable one at simplicityhomecare.com click on the download tab and select manuals and then under sergers chose your model. Good luck with your project.
Oct 03, 2009 | Simplicity Serge Pro SW432 Mechanical...
Can't get the material to feed automatically
The teeth on your feed may be clogged with lint... follow instructions in the manual to remove the cover and clean out the lint...has the machine been oiled??
Aug 04, 2009 | Simplicity Serge Pro SW432 Mechanical...
MyLock 634D won't serge
Check that your lower looper is actually threaded and not tangled with the upper looper (needle thread) when it moves. I wish they'd include pictures in the manual how to lay the thread.
Apr 05, 2009 | Janome MyLock 634D Mechanical Sewing...
Needle help
using a pair of needle nose pliers grasp the needle as far up as you can and pull down. Sometimes a slight twist will help.
sewman7
Jan 05, 2008 | Simplicity Serge Pro SW432 Mechanical...
Simplicity Serge Pro SW432 Mechanical Sewing Machine Logo
157 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
