Question about Whirlpool Duet GHW9150P Front Load Washer
Soap Dispenser Problem
The soap is not dispensing. I'm using HE powder Tide. Never had a problem until this past week or two.
    President:
  • 878 Answers
Bono, you want to see if your dispensor motor is working. Remove the 3 screws for the top in back and slide the top off toward the back. Put the machine into the test mode by; turn the machine on, select the drain spin cycle, push the spin speed button until no spin is lit, push the prewash option 4 times until C:00 appears...Let it run it's auto test. When it shows C:02 it is activating the dispensor motor, you can observe it on the left side. Catriver...post back.
Posted on Feb 24, 2007
Dishwasher soap dispenser does not release(sometimes partially)and as a result dishes are not cleaning
the solenoide which pops open the soap lid may be faulty.
Better to poar your dishwashing powder or tablet in the bottom of the dishwasher tray until you get the machine repaired. You may want to do a prewash rinse first, then stop the machine and add your soap.
Make sure not to use too much soap. Just the normal amount as you would use in the soap dispenser.
Ash
Oct 27, 2009 | Dishwashers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Soap not being used
We learned from our new Duet that when washing with Tide soap powder, there is an adjustment inside the pull out drawer where the soap powder goes. You will see a grey plastic slider that goes to the right for liquid soap & to the left for powder soap.
Moving this slider to the left corrected this problem - not using all of the soap powder needed - for us.
Good luck !
Marilyn in FL
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rinsing detergent from dispenser
Use gel run a few cycles and help clear and then don't overfill w gel soap
Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Soap dispenser not working
It sounds like the water valve has a clogged filter.  Shut the cold water to the washer off, disconnect the hose and remove the filter screen in the washer water valve.  Clean out the filter with toothbrush.  Reinstall and everything should be ok.
Feb 18, 2008 | LG WM-1485FHD Front Load Washer
Could SOAP DISPENSER be caked with soap???
POWDERED DETERGENTS GET CLOGGED ALOT IN THOSE DISPENSERS. I ADVISE CUSTOMERS TO FILL THERE WASHER AND ADD SOAP WHEN IT STARTS TO AGITATE WHEN USING MORE THAN A 1/2 CUP OF POWDER ... THEN ADD YOUR CLOTHES ... THE WASHER HAS A SAFTEY SWITCH WILL STOP MOST WASHERS WHEN AGITATING OR IN SPIN CYCLE,SO YOU CAN LOAD CLOTHES ... OTHER THAN THAT ... ALL YOU CAN DO IS KEEP THAT DISPENSER FLUSHED OUT WITH HOT WATER AFTER EVERY WASH. JUST POUR HOT WAYER TROUGH IT ... IF THE WATER BACKS UP (EVEN WITH A SLOW POURING) THE DISPENSER IS PLUGGED AND NEEDS TO BE FLUSHED OUT WITH A HOSE. GOOD LUCK AND STAY DRY !!!
Apr 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Whirlpool Duet GHW9150P Front Load Washer Logo
249 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
