I charged the battery up yesterday for an hour an put it back in with a full charge this morning i tryed to start it nothing the battery saver light came on
SOURCE: Suburban won't start, we don't believe it's the starter
first try to check the fuse of the ignition if it is ok or clean coz some times when it has a corrosion it has the tendency of having a delayed power transmital . if it is fine then check the starter relay if it is good coz it also having a power surge so you have a delayed power to your starte...
SOURCE: Dead battery even after 12 hours of charging?
it sounds to me that you could just have a bad connection at the battery post. look to see if there is any corrossive build up on them. this can happen over time. it is also possible you have a dead cell in the battery. your best bet is to remove the battery and take it to any major auto parts store. most of the major retailers will check the battery free of charge. hope this helps
SOURCE: battery not charging light comes on. new battery
I don't know what kink of car you have, but some will have a alternator fuse, also with a volt meter check voltage on big wire at back of alternator should have 13.5 + volt's, then check voltage at battery should have same voltage there also, do this with car running, if you do not have same voltage at battery less short between alternator and battery or bad fuse. There also some fuse links at starter on some car's.
SOURCE: 2009 Impala won't start. First message
turn on your car and remove the ground cable from the battery, if the car dies it's time for a new alternator, if not take your battery in to be checked. The other message(traction control) may be just due to a faulty battery/alternator.
