Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy heater 110btu kerosene starts and shuts off?
Hsi igniton type.heater start up and runs normal for 30 seconds or so and shuts off? photo sensor bad? no repair attempt made yet and would rather diagnose the problem before throwing parts at it. can the blue wires be bypassed? i already know my thermostat control has a dead spot that won't work in part of the lower setting position but could this be gone completely now? or can it be bypassed?when turned all the way up heater still starts shuts off then must unplug and retry then will run again for 10 to 30 sec. no other symptoms no smoke or excessive fumes from heater. the problem just started all of a sudden after using heater in the garage for 6 hours. and yes it has fuel in it lol... any help would be greatly appreciated. thanks.
    Problem Solver:
  • 6 Answers
I would think that your photocell is bad.... or if your heater has a circut board... the relay or the board could be bad... i dont believe that is is your thermostat for the reason that it will still fire up even though it doesnt run very long... usually they just randomly stop running because the photocell is not detecting a strong enough flame... you could try turning your pump pressure up to get a better flame and see if that solves your problem... the pump adjustment screw is is located in the plastic cover on the back of the pump on the back of the electric motor... it takes a straight head screw driver to adjust...
Posted on Dec 27, 2010
  • 108 Answers
I would say the thermostat is bad after reading your problem over several times. There is no reason to suspect a wiring problem, and I strongly suggest you don't bypass anything! A fire or explosion could result. Replace the thermostat as a probable cause.
Ray
Posted on Dec 09, 2008
Runs than shuts off after a few seconds
Is this a propane or kerosene heater? If it is kerosene, check your fuel, clean your tank and start with fresh fuel. Check your fuel filter/air filters at the back of air pump. Make sure your ignition system is working.
Dec 01, 2010 | Reddy Heater-30-55,000 BTU Variable
R100 reddy heater, low pressure forced air heater. the heater ignites, motor runs for 30 seconds then shuts down. photo cell good, filters clean, no ignition board, pump pressure unknown.
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Thanks
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Starts then shuts off
if it starts and shuts off the flame sensor is dirty. Take cover off and clean flame sensor with scotch brite. If it dosen't light at all you have an igniton problem
Nov 28, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
MY KEROSENE HEATER STARTS, RUNS MAYBE 5 MINUTES THEN SHUTS OFF
Same problem I had and it was the CAD/flmae sensor. you can get one that will fit from Mr. Heater for 3 bucks or from reddypats.com for 18. the wires are a different color but all you do is clip them and splice them to your old wire harness. It does''nt matter how you hook them as there is no hot and ground just a complete circuit.
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Have john deere 50 kerosene space heater has fuel,new plug,
if it trys to start when you turn the thermostate then thats not the problem, it has to be either the high heat limit control or the flame sensor. Mine did the same thing and I also thought the eye was working but as soon as I changed it the problem was solved. Pretty much all flame sensors are the same and you can get one from Mr. Heater for less than 3 bucks, same with the limit control.
Jan 23, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Kerosene Reddy Heater, fan comes on, but it won't ignite, it just blows kerosene out the front. There is no electricity getting to the plug. Please reply soon, I need it tomorrow!! Thanks
Your description does not leave much to go on, because you don’t state the model heater that you have. You see, there are 2 different technologies that come into play on portable kerosene heaters. First there is the older version spark plug type heater, and, second there is the newer computerized type with Hot Surface Ignitor (HSI) technology.
Since you state "There is no electricity getting to the plug", the KEYWORD here is PLUG. I am going to assume that you have a spark plug type heater. NOTICE: if your heater has HSI technology- disregard this post because it will not apply.
Causes for "no electricity to the plug":
  1. no electricity to the unit
  2. a defective Safety Control (reset)
  3. a defective photocell
  4. a defective Ignition Control (transformer)
  5. loss of ground to the Ignition Control
I am including a link to some troubleshooting tips for spark plug type heaters. These heaters are relatively simple, but, be careful. Stay away from the fan and take precautions from the obvious shock hazards. Troubleshoot each of the above until you find the problem.
Dec 04, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
819 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
