Screen with blue mobile is shown with white arrow to connect oit to USB i think
SOURCE: i have a samsung GT-S5233A mobile,i can't install java apps on it
how to transfer photos from samsung gt s5233a to pc
SOURCE: SamsungGT-S5233-A:How do i block message from a particular mobile
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
>>now you are all done.
>>no need to buy medicine for your head aches.. :-D
regards.
Testimonial: "Very much relieved ... thank you"
SOURCE: How to connect samsung mobile internet without pc suite?
I found A PC blue tooth at wallmart for less that 20 bucks, transfers pics audio everything on all my cells. plugs into usb port all you have to do is install disc from blue tooth, make blue tooth on and visible on cell phone then pair them code 0000
SOURCE: The screen on my Samsung GT-S3100 is white and
This is a program or software issue or some components could have gone bad. But you need to try to do basic steps first. Try to power cycle the phone. Remove the battery while the phone is turned ON. Leave the battery out for 5 minutes, then put it back in and turn ON the phone.
If same problem occur, send the phone to your wireless provider or to the manufacturer and have them fix it for you.
Thank you and good luck!
Testimonial: "Very speedy reply, I had tried already tried the advice given but thanks for the help"
Problem solved by Samsung, telephone has been completely reinstalled.
