Question about Danby Silhouette DWC512BL Wine Cooler
Danby Silhouette DWC513BLS lower back fan noise.
What is the exact type of lower back fan ? How to replace it? Thanks.
  • ktcrkelley Jan 25, 2009
    fan barely turning and making high pitched noise. Refrig still cooling at this point.
  • Anonymous Feb 22, 2009
    We had the same problem and after reading another blog, http://www.firstov.com/topic/wine-cooler... , replaced the fan with a different manufacturers fan (~$20) in hopes that it would mitigate noise by manufacturers original fan.
    Time will tell.
  • 3 Answers
Called Danby customer service. Requested repleacement part of lower fan unit. Located at bottom right on back of unit. Part was $6.68 plus shipping. Less than $10 total. At my door in 3 days. Plug and play piece that was easy to change. A very cheap fix and I hate to think what a service call would have been. Danby ph # is 800-263-2629.,
Posted on Feb 01, 2009
I am in need of a fan motor for my Danby Frig. Paret #JG50.DQ-10. Cannot find it anywhere. Suggestions?
The problem with the factory fan is that it is a sleeve-bearing fan. On average, a fan should operate for about 50,000 hours, which if it runs continuously would be over five years. However when the operating temperature rises or the fan is installed "not exactly" vertically, it will have shorter life.
I had to replace my fan two times withing two years since we bought the unit! Plus the stock fan becomes quite noisy after a couple of months of work.
With all of these problems I did some research for better fans and decided to purchase a ball-bearing fan to install it into the cooler by myself.
Ball-bearing fans on average outlast sleeve-bearing fans by 50 percent and produce less noise.
It's very important to purchase the right AC 115 Volts fan for this Danby wine cooler.
The original fan is Rullian Science RAL 1225S2 (120x120x25 mm in size, 100-125V AC, 0.09A)
The replacement model is Orion OA12AP-11-3TB which I got for $16.75 from Mouser Electronics (mouser.com). The replacement model is ball-bearing cooling fan with slightly higher/better parameters, which will help to cool down the wine cooler coil faster.
To replace the fan you need to tilt the wine cooler on the side and unscrew two small screws at the bottom that keep the original fan in place, remove one screw to the black box where the fan wires are attached and unplug these wires. Then you just need to replace it with the new fan and test that it works properly. If you never used Soldering Tool before you probably will be better off with getting some help from certified electrician - it still will be less expensive than getting this fan ordered every year from Danby.
Nov 06, 2012 | Danby DWC513BLS Wine Cooler
I am looking for the cooling fan for a Danby Silhouette DWC512BL-1 wine cooler. A google link took me to your site but I don't see any links to Danby parts.
As I have worked on a few ELECTROLUX wine coolers and they do not have a cooling fan for the inside of the unit are you speaking of the one under and in back of your cooler if so then it is a condenser fan motor it will be 110v and your local appliance store should be able to order one close enough to work in design and rotation of it. Hope this helps.
Apr 09, 2011 | Danby DWC513BLS Wine Cooler
Fan started making some noise as it struggles to get to full speed. Sometimes, but unpredictably, I can tap the fan and it runs fast, smooth and quiet. Clearly, that is not a long term solution. If...
I have the same issue I am attempting to replace the fan. It is a 120v .09 amp fan so it shouldn't be difficult to replace. My u it is from a different cooler but the same model of fan. Leads me to think this is a common part and a common problem.
Sep 05, 2010 | Danby Silhouette DWC512BL Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Danby DWC513BLS does not cool. Fan is on, but compressor does not turn on to lower temperature even when temperature is turned down. Where does one get parts for this online
Before you worry about where to get parts,you need to know what is wrong and what parts you will need. When a compressor does not run but the fan motor does, then either the compessor is bad (in which case you need refrigeration expertise) or the starter components have failed ( in which case you can replace. The two most common failed parts are the start relay or the overload (both attached to the compressor. Goodluck, Macgivor
Jan 31, 2010 | Danby Silhouette DWC512BL Wine Cooler
Loud noise
The compressor fan is making the noise and causing overheating as well. Easy fix. Call Danby with model # and they can figure out correct fan. Part will cost around $10 and is easy to replace. Plug and play with screws. Good luck
Apr 21, 2009 | Danby Silhouette DWC512BL Wine Cooler
Noisy fan on DWC513BLS
The upper fan is mounted to a board inside the refrigerator near the back. To access it, you have to remove all of the shelves completely. Once you do that, you should be able to see the screws that hold the backing in place. Remove all of those, and pull the board out. The fan is mounted directly to the board.
When you replace the fan, I suggest you use rubber washers or grommets when you mount the new fan to the board. That will dampen the vibrations that otherwise are amplified by the board itself.
http://www.adrianmccarthy.com/blog/?p=79
Jul 15, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Wine cooler noise
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Danby Silhouette DWC512BL Wine Cooler Logo
1,192 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
