Question about GE JVM1441 Microwave Oven
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
My GE Spacemaker starts buzzing about 2-3 seconds after I press the start button. The turntable does not spin, the lights come on, and the microwave "fan" sound does not kick in. The weird thing about it is that I tested a mug of water and sure enough the microwave "buzz" still heated it up. Is this safe? What is wrong with it and how can I fix it? Please help. Thanks in advance!!!
  • eg25 Dec 19, 2007
    I have a Kelvinator KM235M4 with a similar problem:
    turntable spins,buzzing sound from inside fan dosent switch on
    it still heats, clock is working, but dosent sound right
    what is wrong with it? do I need to take it in be repaired? is it unsafe to work with it ?
    HELP!!!!
  • Anonymous Mar 31, 2014
    I have a jvm1750 from 2007 - the turntable is no longer working. Can this be repaired/replaced? Can the microwave be used safely if the turntable is not operational
Erevthing works turn table works heats, cooks, clock works ,, BUT after i push start a Buzzing noise happens twice but only when i put it on IS IT SAFE WILL I DIE!!!!! HELP!!!!!!
Posted on Oct 09, 2008
  • GE Master
  • 9,149 Answers
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Posted on Feb 25, 2007
2 Suggested Answers
MicrowaveSvc
  • 9149 Answers
SOURCE: Microwave Buzzing
It is not safe. If a microwave oven cooks without the cooling fan running, then your magnetron will soon overheat and be destroyed. At our Web site, we have important safety information plus information on diagnosing and replacing door switches. Our site is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If it;s not a door switch, then it may be a problem (such as a bad relay) on the control board. We repair these nationwide for $32.50 postpaid in most cases, and you can find out more through that link, too.
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
GE JVM1860CD001 turntable does not turn. Buzzing sound. Sometimes sensor error, close door. Heats and seems to work most times.
If this is an old unit. Unplug it. Take all of the outer screws off and remove the metal cage. Turn on side and look on the bottom at the rubber band drive. It might be wore out of stuck. Try to turn it manually.
Jan 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm160wj01 was working and suddenly started buzzing, gave bad electric/burnt smell and buzzes. Still buzzes and does not seem to heat now.
Sounds like the magnetron just shorted out. Its the part the generates the microwaves that heat the food. Buzzing sounds are a symptom of a shorted mag. Usually not worth fixing since the magnetron costs almost as much as a new oven. Sorry.
Jul 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not work
please dont forget to rate me on this issue...
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 Buzzing
Chances are this is a problem on the control panel. We repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Apr 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Buzzing
Feb 24, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1441 Microwave Oven Logo
494 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
