Question about iLO XM-MP3-CD Car Stereo
Kenwood KDC - MP 235
My Kenwood in dash stereo keeps flashing "PROTECT" across the face plate. The unit was on and it just switched over to this flashing message. I have removed the face plate numerous times. i have not tried disconecting the unit or diconecting the car battery. Please help
Thanks
    Sergeant:
  • 300 Answers
I would also check the speaker outputs from the deck. If any of the speaker outputs are touching any metal on the vehicle, it could give that message.
Posted on Dec 09, 2008
Why does stereo say protect
Check if a speaker wire come off or some other wire, That will cuase it to go into the protect mode,Allso if you have a amp hooked up to it, End continully have the music cranked up the system will over heat ,That can cause it allso to go into protect mode, There is a reset button on the face plate but it is not marked,
Nov 02, 2012 | Kenwood KDC-248U In-Dash CD, MP3, WMA Car...
Protect
You have to reset your system... Use a pen to push a small button that's located in the front of the face plate. That will reset the system...If it gets stuck on standby, just push the SRC button on the face plate or on the remote..
Apr 18, 2010 | Kenwood KDC-MP235 CD Player
I have a kenwood kdc-w5541u cd receiver, when i switch it on it says protect. why is this?
Short in one of your grounds. Also their should be a little pin hole on front of face plate. if not there take off face plate should be on the head unit inside. just take a needle and press the little button
Feb 19, 2010 | Kenwood Car Audio & Video
Its on protect mode and i cant get it off
Look on the face plate for a really small hole. Put the tip of a pen in the hole and hold it for a few seconds. Your system should then re-set. If the Protect signal keeps coming on, take it to the dealer to make sure your stereo is wired properly....hope this helps
May 02, 2009 | Kenwood KDC-MP235 CD Player
"PROTECT" is displayed on the car stereo when turned on
This is really easy to fix. Look on the face plate for a REALLY small hole. Put the tip of a pen in the hole and it should work. This usually means the stereo isn't wired properly so if the PROTECT keeps coming on after you've re-set it, take it to a dealer. To make sure you're everything is in properly. Hope this helps...
Jan 26, 2009 | Kenwood KDC-MP228 CD Player
Protect mode
my stereo kenwood kdc-mp2032 is in protect mode, í lost my manual, and i don´t know how quit this mode. can yuo help me?
Jun 19, 2008 | Kenwood KDC-MP2032 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Jan 09, 2008 | Kenwood KDC-322 CD Player
My stereo is flashing the work "PROTECT" across the front
In a Kenwood deck, "PROTECT" usually means that one of the speaker output wires is shorted. The first thing to do is pull the deck and inspect the wiring at the back, making sure there aren't any pinched or exposed wires. If a speaker wire is pinched against the deck chassis, or bare wire is touching dash metal, it can cause your problem. If you don't see anything obvious, disconnect all speaker wires from the deck, then turn it on. If it still flashes "protect", then you have a defect in the unit. If not, then re-connect the speakers one at a time until you find the one that causes it to go into Protect mode. Usually if you don't find a pinched or shorted wire behind the radio, the problem can be found at the speaker itself. This is especially common if you've installed after-market speakers; if a speaker terminal connection has come loose and is now touching the speaker basket or mounting surface, it will shut down the deck.
Jun 07, 2007 | Kenwood KDC-MP5032 CD Player
iLO XM-MP3-CD Car Stereo Logo
313 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Libran Moreno
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
