Question about Mitsubishi WD-52526 LCD TV
After tv is turned on it shuts off automatically
I turn my television on, and it instantly shuts off on its own
  • Cade Austin May 11, 2010
    Do the indicator lights on the front of the unit flash any type of code? Does the "timer" or "lamp" light flash at all?
This is indicative of a failing lamp and/or dirty filter. The set keeps track of the hours of operation and trys to inform you when it is having problems. I ignored the signals and ended up with a blown lamp preceeded by my cleaning a dirty filter. On the bright side (no pun intended) my lamp lasted over 3 years without cleaning the filter. I was able to purchase a replacement lamp on ebay with overnight shipping and insurance for 160.00US, replaced the lamp and am back up and watching a better brighter picture.
Posted on Jan 15, 2009
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
What makes my tv shut off when turned on?
A short circuit or a loose solder point can cause this.
Mar 25, 2013 | Zenith Televison & Video
My tv automatically shuts off then power button flashes 11 times. Can't get tv turned back on
11 blinks Fan SOS PB Board. Either the cooling fan or its control board is faulty. You have to check and locate which one has the fault. Check this link and select the site mamed 'Electro-help' for more details.
Jul 04, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
It wont turn on anymore. it fires then instantly shuts off, doesnt even flash screen. standby lights still flash and its trying to turn on, just cant get on. you can hear the on sound and then the tv...
Depending on the age of your tv, if you hear a rapid clicking, it seems like your ballast is starting to turn on your tv but it's not able to. (1) Check your lamp, (2) reset the lamp timer, (3) make sure the cover panel is all the way. the positioning sensor might not be detecting the cover all the way in.
Personally I think you're experiencing a ballast problem.
Apr 20, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I have a RCA HD52W59 TV. Shuts off automatically.
Power supply is my initial thoughts, but then again it could be that one of the three CRT's tubes has an issue.
My thoughts is that it would be best to bring it to a good TV repair shop.
Why spend money on a power supply and then find out it's a CRT.
Blessings,
A/V Media Guy
Nov 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
TV shutting down automatically after a minute
I also have this TV but mine will not power on at all. Did you ever find a solution?
Max.
Jun 25, 2009 | LG MU-60PZ10 60 in. Plasma Television
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Setting automatic shut off
How do I set on PCB to automatic tv shut-off?
Jun 29, 2008 | Curtis-Mathis CM19011 TV
Tv turning off automatically
I have the exact same problem. did you get a fix?
Jun 08, 2008 | Pioneer SD-P50A3-K TV
Mitsubishi WD-52526 LCD TV Logo
202 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
