Question about Brother SX-4000 Typewriter
Types wrong letters
I have tried every way I can think of to insert the daisy wheel, but obviously there is one I haven't tried. It seats well, but if I type an "a" I may get an "h", (it changes everytime a re-insert the wheel), but it is consistent, I will always get an "h" for an "a" as long as I don't re-sert the wheel. I have tried hitting C reset, there is no beeping, but no change in the letters. Thanks for any help...
  • bookkeepi502 Feb 03, 2009
    When I type the wrong letters appear. I was going to try the code + keyboard method, but I don't see anything about keyboard. Where might I find this botton?
Check keyboard setting it is a international typewriter, hold down code key and press keyboard to USA? daisy wheel is bad or motor is out.
Posted on Feb 26, 2007
The nakajima ae610 types two vertical lines instead of letters
The print hammer is striking between the letters. Two thing
you may have a petal, letter broken off. If its the same letter every time usually thats it, need new daisy wheel.
Or Homing is off when the wheel turns hammer hits between letters. Needs repair.
Or
Daisy wheel petals are bent.
Dec 12, 2016 | Nakajima Office Equipment & Supplies
When keys are depressed the corresponding letters don't come up
The printwheel is not seated properly..the daisy wheel must spin and seat itself properly or you will get the wrong letters. The instruction book covers this a little better.
Hope thios helps
Mar 28, 2011 | Brother ML-300 Typewriter
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
When typing with my brother gx-6750 it types weird lingo is the type set messed up or can I reset them?
Your daisy wheel letters are bended not straight.
Switchoff just remove your daisy wheel & remove the daisy wheel from its cover & see all the letters should be straight.If any of them is bended jst make them straight by your fingers dont press too hard & then fix the daisy wheel back & switch on typewriter.
Jul 20, 2010 | Brother ML-100 Typewriter
Types wrong letters
Remove the correction tape and try it. If it works you either have it on wrong or it is a tacky L/O tape they will give it fits.
DickyO
May 16, 2010 | Brother GX-6750 Typewriter
My ML300 types wrong letters and I have done everything that the manual says to do. Where can I buy a new daisy wheel? I think mine has one tine overlapping another.
We have wheels in stock they are 39.95 including shipping, however the problem may be a broken printwheel homing pawl and you will need a tech.
DickyO
Cleveland Business Machines
216-241-0027
Apr 01, 2010 | Brother ML-300 Typewriter
Wrong letters are printed
The Daisy wheel is probably in wrong..reinstall it until it spins to the home position. Its either that or an adjustment to the print wheel motor.
Oct 07, 2009 | Swintec Office Equipment & Supplies
How do you fix the daisy wheel for Mastertype 1
It is usually that the printwheel is in wrong. Make sure the pw does not have any bent "petals" on it making it bind.
After it snaps in and closes it should go to it home position. If not keep trying a couple of more times and it should seat in.
Oct 07, 2009 | Office Equipment & Supplies
Wrong characters
change Cassette daisy wheel.one with the letter
Jun 16, 2009 | Brother EM-530 Typewriter
Typewriter
open the printer remove a wheel and try to clean printer with compressed air,some of your sensors on printer are dirty
Jan 11, 2008 | Office Equipment & Supplies
Brother SX-4000 Typewriter Logo
341 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
