Question about Canon PIXMA MP460 All-In-One InkJet Printer
Paper jam, how do i get to it?
I've got a paper jam, but can't find it.  I cannot find my manual, so I'm not sure if there is some section that can be opened that I have not found.  I have opened the lift which allows you to change print cartriges, and see no problem.  I had just changed the color prior to this problem.  Please advise.
  • Anonymous Dec 15, 2008
    My canon mp460 wont take the paper in either and i checked for paper jams and theres nothing...... i think its just the printer that broke.
    President:
  • Canon Master
  • 990 Answers
Go through the paper path you can find a senser, that sensor should be out off track, just put it back
to their own position.
Posted on Dec 08, 2008
My HP4100 keeps jamming under the toner cartridge. I have a repairman look at it 2 times and he cannot figure it out. Does anyone know what would be causing the jam. It seems to happen mostly on short...
1) Check all the paper jam locations (see "Clearing paper jams" in your printer manual). A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
2) If you are using a duplexer, check all the areas (including under the duplexer).
3) Check that the paper is correctly loaded in the tray - that all paper tray adjustments have been made, and that the trays are not overfilled. Make sure the paper is under the front and back tabs. (See the section on "loading paper" from your printer manual.)
4) Check that all trays and paper handling accessories are completely
inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
5) Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
6) Try printing to a different output bin or tray
7) The sheets might be sticking together. Try bending the stack to separate each sheet.
8) If you are printing from tray 1, try reducing the size of the stack.
If printing from the envelope feeder, make sure it is loaded correctly,
9) If you are printing small sizes, feed paper short edge first (see
the "Guidelines for printing custom-size paper" in your printer manual).
10) Turn over the stack of paper in the tray. Also try rotating the paper 180 degrees.
11) Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the "Paper Specifications" in your user manual).
12) Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or irregular paper.
13) Check that the environmental conditions for the printer are met (see the "Environmental Specifications" in your printer's user guide).
14) Avoid using paper that has already been used in a printer or copier.
15) Check that the power supplied to the printer is steady and meets printer specifications (refer to the "Electrical Specifications" in your printer's users guide).
16) Clean the printer and rollers (refer to the "Cleaning the Printer" section of your printer's user's guide).
17) Perform preventative printer maintenance if maintenance is due (refer to the "Performing Preventative Maintenance" section of your printer's user's guide).
Nov 21, 2013 | Office Equipment & Supplies
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
Cannot copy two side.paper always jam
Are you sure there is not something blocking the paper going inot the duplexer. I've had one of the fuser separation claws fall off and block the path. Now if that is not the case then check to make sure some of the sensor arms don't have paper cuts in them. This will cause an intermittent delay jam. Jam codes in service mode will also help.
Jun 17, 2011 | Canon NP 6050 Copier
Canon ir400 paper jamming at heater section
just remove the cartridge and remove the paper essay
if you don't know how to remove the cartridge just see the user manual booklet or download user manual from cannon website for proper model printer user manual
Apr 16, 2011 | Office Equipment & Supplies
Paper jams every sheet. Checked the paper weight, made sure it was faned edges and not rolled. Catches on the left side as it rools in from the drawer. What can I do to fix it. I have used it many...
Marie, there is something stuck between the paper tray and the transport section of the copier. Probably a small piece of paper. try to push a piece of paper up from the tray to the rest of the machine to push this obstructing paper out of the paper path. Also try using the handfeed section on the right hand side of the machine by folding down the tray and putting paper in it. You may have to choose this "manual" feed tray on the operation panel. Good luck !
Feb 20, 2011 | Canon imageCLASS D860 All-In-One Laser...
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
I have a peice of paper jam in the output area of the imagerunner 1670, but the machine dosn't open to allow access to this area. how do i get the paper jam resolved.
Your jam is in the fuser section of the machine. Unfortunately this area this area is not for users to access. You will need to remove covers to get to the fuser unit. You may be able to access the paper by removing the whole drum unit (make sure you remove the toner cartridge first). Then look into the machine to the left. You may see the tail end of the document for removal. Otherwise, you will eed a service manual to dis-assemble it yourself.
IR1600 Service Manual
May 05, 2009 | Canon ImageRUNNER 1670F Copier
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
53 people viewed this question
old marine
old marine
