Question about Sirius STILETTO 100 MP3 Player
Antenna not detected
My Stiletto is updated, but when I put it into the car dock, it says Antenna not detected. I know it isnt the car cradle because I have two of them for two seperate vehicles and the same thing happens.
  • 1 more comment
  • Anonymous Mar 10, 2009
    Stiletto says "antenna not detected" when plugged into two separate car docks with or without the battery installed. When the unit is disconneted but on, it says "acquiring signal" and switches immediately to "antenna not detected" when plugged into the dock. This does not happen on the home dock.
  • clubchuck1 Apr 14, 2009
    My styletto 100 works great on the boombox, but once I plug it into the car cradle it signals "no attenna detected". I have bought TWO new cradles, 2 brand new antenna's with the same frustrating results.. I ended buying a second styletto as well, and guess what... same problem. HELP
  • Anonymous May 02, 2009
    I cannot recommend the Stiletto to anyone. I have had mine a year, with nothing but problems. I repeatedly get the antenna connection problem, but also my unit does not charge in the car dock, but if you take the power cord out of the dock and plug it into the bottom of the unit itself, it does charge. So dock right? No, I've been through three. I've had it with Sirius and their **** tech support, and plan to simply file a small claim.
    Problem Solver:
  • 5 Answers
I had this problem also. I received a replacement unit but the problem persisted. I would have to reset it to get it to work, loosing all data. I was also using the FM transmitter but it would disable that function (greyed out). After I connected the radio direct through an aux. audio port, I haven't had any issues.
Posted on Jun 12, 2010
One thing I suggest you try is using a second docks power cable in a different power source.
I had every problem you could imagine with my dock: antenna not detected, FM direct failing, picking up the satellite signal but not charging, then charging but failing to get the signal, the remote behaving badly, etc. For a year I tried to figure out what was wrong, testing every cable, the unit, three docks. The guy who professionally installed my system tested the power cable with a multimeter to make sure power was going to the dock. We could not figure it out.
Then it occurred to me that the dock may just not be getting ENOUGH power. The guy who put my dock and FM direct in with my car install kit certificate wired my power cable directly into my car power, under the driver's dash, so that I would not have to plug into my cigarette lighter.
While this may not happen with every car, it happened with my 2005 Altima. Whatever he had spliced into was not giving the dock enough juice to run everything. As soon as I plugged a second power cable into the cigarette lighter jack and put that in the dock, full powering of everything with no failures. If you find that to be the case, bring the car back to your installer and have him fix the connection, or just live with the cigarette lighter connection.
I also have two connections for power outlets, so you may want to even try different ports in your vehicle if one does not give you success.
Posted on May 05, 2009
    Problem Solver:
  • 7 Answers
If its not the recivers its the antenna connection.Try turning it slow.If you get to work or get a new 1 keep a loose bend in wire near plug an afix it somehow (behind bracket,rubberband,something),The optional antenna extesion house wire is even heavyier and puts to much force on end/plug.Good Luck, union kk
Posted on Apr 12, 2009
  • oldcycles Apr 13, 2009
    2 other thoughts,first swap antenna from home to car at least to see if it's the antenna.Like i mentioned you might have to turn wire end (plug) slowly and afix it and turn untill it's good.Other idea is you can download agin this time with your sl radio docked when downloading,you know you'll lose recorded music,etc.,union k
Try docking the unit without the battery attached. The unit will recycle and that may solve the problem. You will, however, need to continue to dock the unit without the battery...
Posted on Jan 29, 2009
My stiletto does not get a signal. It comes in for up to 10 seconds at a time and then nothing, searching. I walked to the top of San Bruno Mountain overlooking San Francisco with no improvement in...
Does it get a solid signal when its in a docking station? Its likely that the internal antenna on the unit is disconnected. Antenna headphones would correct the issue, though they are not very durable at all. I know that our repair guy is able to fix the internal antenna, but I would ensure that is the issue first. Try plugging it into a home dock, car kit, or boombox to see if it works through one of those antennas.
May 26, 2011 | Sirius Stiletto 2 Portable Satellite Radio...
How to debug a stiletto 1
Stiletto 2 ...pin bent...now broke off !
The pin on the Stiletto 2 connector was indented a little last week. This week it broke off and the radio will not work. I am thinking the dock connector would have to be replaced.
Anyone know who can repair this?
Is this a common problem for the Stiletto 2 ?
Thank you !
Mar 19, 2011 | Sirius Hoods Stiletto SL100-PK1 Satellite...
Will the Sirus Stiletto II radio work with an earlier Stiletto dock, either auto or home?
no. stiletto 2 will not fit into earlier model stiletto dock. i order the older model boom box by accident. i tried but will not fit.
Sep 18, 2010 | Sirius Stiletto 2 Satellite Radio Receiver
SL 10 Antenna not detected
I've had this same thing happen to mine frequently - all I do to solve the problem is to remove the battery for about 20 seconds and then reconnect and power it back on. Always works fine after that (knocking on wood)! Hope this helps!
May 17, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Sirius Stiletto 2 Problem
That's one of several problems my Stiletto 2 has. The only solution I've found is to "reboot" the unit. You'll have to remove the unit from the cradle, pop the back off, and remove the battery for a few seconds. Then put everything back together and power it up. It will take a minute or two, but once it reboots it should be fine.
Aug 15, 2008 | Sirius Audio Players & Recorders
I'm recieving a strong signal on my stiletto 2 but no sound on the radio. The MP3 player works with headphones and so does internet radio.
You need the firmware upgrade from the Sirius website:
Bug Fixes
· Reduced incidence of “acquiring signal” and “antenna not detected” messages
while the radio is installed in the Stiletto Vehicle dock (SLV2)
· Improved audio quality and distortion reduction
· Reduced incidence of long block recording and Radio Replay corruption
How to Get this Release
Updating over WiFi:
Subscribers may update Stiletto 2 over WiFi by following these steps:
1. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
2. Turn on the Stiletto 2 and press the HOME button
3. Use the MEDIA DIAL to scroll to Internet Radio
4. Press the SELECT button to connect to Internet Radio
5. Tune to your favorite station and let it play for several hours.
6. Follow prompts on screen to complete the update, then power cycle your radio to
apply the updates.
7. Next go to HomeSettingsDeviceDevice info, if the baseband version is
already 00.14.94 you are done. If not, continue to the next step.
8. Reconnect to Internet Radio and listen for at least 15 minutes.
9. Disconnect, and tune to Satellite Radio. Updating Sirius will be displayed for
approximately 5 minutes.
10. Once the message clears, your update should be complete. Go to the Device
Info screen to verify the update has been successful.
Updating using My Sirius Studio™:
Customers without WiFi access may update using My Sirius Studio™ running on a PC
with an active internet connection:
1. Launch My Sirius Studio™ on your computer. Be sure you are running the latest
version of My Sirius Studio, currently version 1.5.1.
2. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
3. Turn on the Stiletto 2 and connect it to your computer using the USB cable
supplied with your device
4. In My Sirius Studio, click on the gear icon next to the device or go to File
Device Settings Check for Software Update.
5. Follow the instructions that appear in My Sirius Studio™ to complete the update.
Please Note: During the update, your media library must be re-built. If you have a
large amount of content stored or a microSD™ card installed, the process can last
for as long as 10 minutes. During this time the message “updating media library” or
may be displayed.
6. After disconnecting from your PC it will be necessary to power cycle your Stiletto
and connect to Satellite Radio to refresh your channel list.
For additional questions regarding your Stiletto 2 or the SIRIUS service, please refer to
the product manuals. You can also reach the dedicated Stiletto Technical Support Team
at 1-800-869-5364 from 10 AM to 10 PM Eastern Time Monday through Saturday, or by
email at customercare@sirius-radio.com.
Jul 06, 2008 | Audio Players & Recorders
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
Usb connection on sirius stiletto 2 to pc
I had a sync problem with the Stiletto 2 (SL2) and was able to resolve it by the following procedure:
Click "Start"
Click "Run" > Type "devmgmt.msc"
Click "+" next to "Other Devices"
Note: You should see a question mark and exclamation point next to "Stiletto 2"
Right click on "Stilleto 2" (to see menu); then, left Click "Update Driver."
Follow the steps in the windows hardware update wizard.
Apr 07, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Sirius STILETTO 100 MP3 Player Logo
1,301 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
