Range I pressed the button to clean the oven and now the door won;t open that was about 6 hours ago it reads F 1 How can I get the oven door open? maytag super capicaity plus
1. move door to locked position 2. Press self-clean pad. 3. press up or down to select clean time (it will flash 3:00) 4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set. 5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked. 6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened. ** to cancel press cancel. Hope that helps!
CLEAN PAD Use to set a self-clean cycle or a delayed self-clean cycle. One press of the Clean pad sets up an immediate clean cycle. A second press of the Clean pad sets up a delayed clean cycle. • Clean oven frame, door frame (area outside of gasket) and around the opening in the door gasket with a nonabrasive cleaner such as Bon Ami*. These areas are not exposed to cleaning temperatures. • Remove air grille. • Remove oven racks. If racks are left in during a clean cycle, it may impair function and they will discolor. Turn off the oven light and close door. * Brand names for cleaning products are registered trademarks of the respective manufacturers. TO SET FOR IMMEDIATE START: 1. Press Clean pad once. 2. Press the Auto Set pad for 3 hours of cleaning time, press again for 4 hours and again if 2 hours of clean time are desired. 3. CLEANING and LOC plus the clean time will appear in the display. 4. When the clean cycle is complete, CLEANED will be displayed. LOC will remain on until the oven has cooled (approx. 1 hour). 5. When the oven is cool, LOC will no longer be displayed and the door may be opened. 6. Wipe out the oven interior with a damp cloth. If soil remains it indicates the cycle was not long enough.
TO CANCEL SELF-CLEAN: 1. Press Cancel pad. 2. If LOC is NOT displayed, open oven door. If LOC is displayed, allow oven to cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
CAUTION: SHOULD AN OVEN FIRE OCCUR,
CLOSE THE OVEN DOOR AND TURN OFF THE
OVEN. IF THE FIRE CONTINUES, USE A FIRE
EXTINGUISHER. DO NOT PUT WATER OR FLOUR
ON THE FIRE. FLOUR MAY BE EXPLOSIVE.
To set the controls for a self-clean cycle:
For satisfactory results use a 2 hour self-clean cycle for
light soils and a 3 hour cycle for average to heavy
soils.
1. Be sure the clock shows the correct time of day.
2. Press Clean. "— — —" appears in the display.
3. Press the Up Arrow until "3:00" appears in the
display for a 3 hour cycle, or press the Down Arrow
until "2:00" appears in the display for a 2 hour cycle.
4. As soon as the Up Arrow or Down Arrow is
released, "CLN" appears in the display.
5. As soon as the controls are set, the motor driven
lock will begin to close automatically and the "LOCK"
indicator light will flash. DO NOT open the door while
the light is flashing (it takes about 15 seconds for the
oven door to lock).
6. The "LOCK" light will glow until the cleaning cycle is
completed or cancelled, and the oven
temperature has cooled.
When the self-clean cycle is completed:
1. The time of day or “END” will appear in the display
window and the “Clean” and "LOCK" light will continue
to glow.
2. Once the oven has cooled down for about 1 HOUR
and the "LOCK" light has gone out, the oven door can
be opened.
3. If “END” is in the display and the “Clean” indicator
remains on, press Clear/Off. The time of day will
NOTE: When the oven is cool, wipe away any residue
or powdered ash with a damp cloth or paper towel.
Stopping or interrupting a self-cleaning cycle:
If it becomes necessary to stop or interrupt a selfcleaning
cycle.
1. Press Clear/Off.
be opened.
3. Restart the self-clean cycle once all conditions have
been corrected.
How the ES 200 operates:
CAUTION: NEVER ATTEMPT TO REMOVE EITHER
THE BAKE OR BROIL ELEMENT WITHOUT DISCONNECTING
ELECTRICAL POWER FROM THE
RANGE. ELECTRICAL POWER IS CONNECTED
TO THE ELEMENTS WHENEVER ELECTRICAL
POWER IS CONNECTED TO THE RANGE.
The ES 200 electronic oven control system is made up
of three parts that control the bake and broil elements,
and the locking of the door in the self-clean cycle.
1. Electronic oven control.
2. Oven temperature sensor.
3. Oven door lock mechanism.
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING 2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION 3. PRESS THE "COOK TIME" BUTTON 4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS 5. PRESS "START" BUTTON 6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN. 7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
I have a crosley but don't know if it is the same model. 1. move door to locked position 2. Press self-clean pad. 3. press up or down to select clean time (it will flash 3:00) 4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set. 5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked. 6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened. ** to cancel press cancel. Hope that helps! RC
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
did that didn't work thanks anyway
