Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
Sony projection kp-65ws510 shuts off blinks 8 times
My tv turns on for a few seconds, I hear audio but no black screen. It auto shuts off after about 5 seconds or so. Then it blinks the red standby light in 8 blink incriments. HELP!
  • AHUVA Dec 08, 2008
    I meant that I do hear video but the screen remains black. thanks
  • Sony Master
  • 4,806 Answers
It could also be the convergence, adjust the convergence again using FLASH FOCUS.
It is recommended to perform FLASH FOCUS about 30 minutes after the
projection TV is first turned on.
Receive a TV or cable TV program.
Press FLASH FOCUS.
The cross pattern appears and FLASH FOCUS begins to
work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle.
If you perform any other operation while FLASH FOCUS is in progress,
FLASH FOCUS operation is canceled.
Unshielded speakers or other metallic objects can cause picture
distortion if placed close to the projection TV.
kind regards
Posted on Dec 08, 2008
    Sergeant:
  • 399 Answers
Eight blinks---- Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402. Intermittent problems-------------------------------- for remaining blinks read the following-------------------------
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective. One blink---- not used for the self-diagnosis. Two blinks---- B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Three Blinks---- B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Four Blinks---- No vertical deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505. Five Blinks---- AKB circuit (AKB), the timer/ standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board. Also check Q218, 219, 220 on the A board. Also, unit can be in IK blanking. Try turning up screen slightly. Six blinks---- No horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 and 516 and the jungle IC, IC206. Seven blinks---- High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Eight blinks---- Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402. Intermittent problems?
    Genius:
  • 2,920 Answers
Have the flyback checked for a short. it sounds like its not working correctly. any shop should be able to tell you for sure whats wrong but im pretty sure youll find out its the flyback
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
I have a sony 65 in rear projection TV, model no. KP-65WS510. I believe the thermal fuse needs replacing, but I cannot locate it once I opened up the back of the TV. Where should I look to find the part...
Your model is a three CRT projection which doesnt have a thermal fuse. What are the symptoms of the set? Does the power indicator blink? If so how many times is it blinking?
May 21, 2011 | Sony KP-65WS510 65" Rear Projection...
KP-65WS510 standby blinks 5 times then it shuts off
This is a indication of high voltage regulation cuircit problem. specifically the cb board. This is a board sony recomends sending to them to get fixed and adjusted
Oct 20, 2010 | Sony KP-65WS510 65" Rear Projection...
Sony kp-65w5510 rear projection tv power button malfuction
Replace bulb and clean cooling fans of dust is the first thing to do. if that doesnt work might start checking capacitors on the power supply.
May 10, 2010 | Sony KP-65WS510 65" Rear Projection...
Cant find reset button
Sony KP-65W510 tv does not have any reset button.
What is the issue with TV? I might help you.
Jan 01, 2010 | Sony KP-65WS510 65" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Tv turns on for 5 seconds no picture and shuts off.. red light blinks 8 times
hello. problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
shaun
Nov 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp51 ws500 red screen, 8 blinks
The 8 blinks is pointing to a bad flyback transformer and may be common with this set. (We have one too.)
High voltage error -- blinks 8 times • T8005 is faulty. (D board)
Jan 01, 2009 | Sony KP-57HW40 57" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-46S4U lose picture after a few second blink of brightness
does the from led blink if so how mant times pause then blink again?
Feb 12, 2008 | Sony KP-48S65 48" Rear Projection...
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
291 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
