Question about Sony VAIO VGN-A790 Notebook
Blank (dark) notebook screen after hooking up digital ext monitor
HELP notebook screen went blank after installing a Samsung 245bw (dual display - XP) on a Sony VGN-A790, 17”, 1920x1200, ATI 600x (256MB) graphics card. Samsung 245bw (bad mistake) was replacing ViewSonic 21' (1600x1200) as dual monitor after the ViewSonic primary screen went out after 2 years.
  • 3 more comments
  • R AF Dec 09, 2008
    No, external monitor works, the notebook screen is actually very dark, not blank. I can see it at an angle. Sony VGN-A790 has an ATIX600 graphics card. ATI's website once had a statement about a known problem w this card of screens going blank when attaching a digital external monitor but they didn't have a fix. Sony ignores the problem. Occasionally the screen with start bright & normal & flicker after a few minutes & go blank/dark. Mine worked fine using a second analog ext monitor for a year. Everything stared when I connected a Sansumg digital 24" 245BW. I've tried everything except reformat the hard drive. Others have reported the same problem with this model???
  • R AF Dec 24, 2009
    any external monitor works. deleted all external monitors, drivers, etc & nothing. screen is actually dark. I can see it at an angle w desklamp. it's as if the digital monitor changed a voltage setting? ati had a brief web note stating connecting a digital monitor & screen going blank was a known problem without solution. tried everything except reformatting the hard drive, taking the case apart & checking screen connections, etc. could this be mechanical or voltage problem? Changing graphic cards? I hate to toss a 1920x1200 17?
  • R AF Dec 24, 2009
  • Nicolas
    Nicolas May 11, 2010
    What happens if u cennect another monitor? is that monitor black to?
  • R AF Sep 09, 2012
    only the primary notebook mnitor is dark, all external monitors work
  • Sony Master
  • 2,219 Answers
I notice a difference in the setup of the two monitors, have you installed the correct driver for the new screen?
Try F8 on startup to get into safe mode, this should allow you to use the default VGA screen, and to reset the correct monitor drivers.
Posted on Mar 07, 2015
2 Suggested Answers
SOURCE: Sony VGN-A790, 17? 1920x1200, ATI 600x (256MB)
I HAVE A SAME SONY AND A SAME PROBLEM
Posted on Apr 22, 2010
Samsung 245BW No Display
have you tried this monitor on another computer? what was the result? Also, try laying the monitor down flat and see if you see any "ghosting" from the characters on the screen. (if the backlight goes out on the monitor, you should be able to see some of the graphics displayed on the screen still with a flashlight or at an angle if the monitor is working)
let me know what you find out
Jun 09, 2012 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 245BW - no image - screen flickered once or twice and then went dark. Reconnected cables, tried different cables - all with same result - no picture. Any usggestions?
It may ahave 24vdc power supply problem due to bad caps, ect, or bad backlights inverter board, worst case will be the lamp assemblies. It will require in-depth troubleshooting.
Please see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20245BW/
Please read my guide if you are going to DIY repair.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 25, 2011 | Samsung SyncMaster 245BW Monitor
Samsung syncmaster 245bw powers on but there is no display.
check your rgb chord found at the back of your monitor, i think it is color blue chord that connects through cpu and monitor..push it tight and it will display again..
i hope it can help you
Jul 25, 2011 | Samsung SyncMaster 245BW Monitor
I have a Dell e1705; I had an external monitor hooked up when the LCD display died. I continued to use it with ext. monitor. However, now on re-boot it won't boot with external monitor unless I go the...
I think now problem is from Monitor side,Check with another monitor and also possibility of VGA driver problem,so reinstall driver for VGA.I think it helps. Let me know.
Jan 08, 2011 | Dell Inspiron E1705, Intel Core 2 Duo...
My Samsung Syncmaster 245bw LCD displays a blank screen.
wardysbiz, I should think SAMSUNG would ship you a replacement unit. It might be what is called a REFURBISHED unit of same model.
In future try not to use the word BROKEN. I thought an elephant stepped on it, or it fell from a great height. Try "nonfunctional" or "inoperative", "has failed" , "never worked" "out of box failure" "Dead on arrival unit" Also contact NEWEGG and ask lots of questions about quality and reliabilty of lcd monitors. Find Your sales receipt or card statement to prove pop. Don't let them off the hook!! I would think turn-around process to be about 14-20 days. 12fixlouie
Dec 10, 2009 | Samsung SyncMaster 245BW Monitor
Samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Nov 13, 2009 | Samsung SyncMaster 245BW Monitor
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
Samsung 245B
Call Samsung. The unit sounds faulty.
Dec 14, 2007 | Samsung SyncMaster 245BW Monitor
Laptop lcd display
sounds like your screen went out, if you need to access whats on your laptop real soon try hooking it up to a desktop monitor via rgb cavble.
Dec 13, 2007 | Computers & Internet
Syncmaster 245bw monitor resolution screen and resolution issues
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Nov 25, 2007 | Samsung SyncMaster 245BW Monitor
Sony VAIO VGN-A790 Notebook Logo
105 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
