3140, tried to use a map update I was given. I believe I deleted the endite drive, now I can only boot to the whit screen and if I hold reset and start, I get the setup screen, have tried with no sucess to reflash . I thought it was similar to an eprom, but my own screw up caused the problem, I should have stopped whil I still had the blue screen, will appreciate if anyone can help, don't mind paying someone if they nail it. As a trader my word is usually enogh for most.
The touchscreen positioning is off on my Maestro 3100. You have to press to the right of something...
(More)
The touchscreen positioning is off on my Maestro 3100. You have to press to the right of something to get it to recognize, and that proves almost impossible for items already on the far right of the screen. I have went through the calibration screen numerous times, done a complete wipe/restore, updated the firmware, even taken it apart to see if the ZIF connector or ribbon cable was damaged which they aren't. The screen isn't cracked or damaged in any way. Any ideas?
WIN Vista PC recognizes Roadmate300, but Roadmate Manager will not recognize it. Need a Vista USB...
(More)
WIN Vista PC recognizes Roadmate300, but Roadmate Manager will not recognize it. Need a Vista USB driver? Other? Thanks much. Bill T.
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this...
(More)
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine which of these things is the real problem? Thanks.
I have no sound any more from my Magellan 3100. How can I get the sound back. Is there a batteries...
(More)
I have no sound any more from my Magellan 3100. How can I get the sound back. Is there a batteries inside that needs to replaced?
