Question about HP Photosmart C6180 All-In-One InkJet Printer
HP Photosmart C6180 all in one, does not copy or print anymore.
We've put in new HP ink cartridges, cleaned the AIO, aligned the printer & got error message might have a defective sensor. Something went wrong & we need problem fixed.
  • nicholas_boo Dec 10, 2008
    Clarification request from swan34 posted 12/8/08.
    The error message was we MIGHT have a defective sensor. We weren't sure if that meant sensor on the ink cartridge or somewhere in the printer. That was not clear. It was not the sensor in the ink cartridge; that was new. We've also made sure the printer name was right.
  • Everett Lin May 11, 2010
    what error message?
    President:
  • HP Master
  • 990 Answers
Put the old cartridge back, if there have same error message then tell me what error message is, if not that's mean new cartridge is defect.
Posted on Dec 11, 2008
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
I received an error message that ink cartridges needed replacing. I replaced the ones stated and checked the ink levels on the computer. The report is that the ones replaced are at 100% and the others have...
If you are using refilled (worst cartridges) or third party cartridges then that is most likely the problem.
If you are using factory new HP cartridges, then you need to contact HP to get the cartridges replaced.
Don
Feb 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
Will not print or copy
When you power up it should come up to "press enter to align cartridges" You need to have all inks installed,and clean the printhead
If any colors are missing it will fail the alignment. Once alignment is complete you should be OK.
Aug 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Brand new yellow ink cartridges are always read as empty
We have a step by step solution posted on our we site at: www.ccl-la.com/HP.htm The problem is air in the ink lines and the guide helps you purge the air from the system and restore printing.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C5280 printer - 1 month old not printing correctly
Usually this problem is indicative of a clogged nozzle. I'm not sure about the track record of the Photosmart C5280 (a lot of Epson printers have this problem, and you just have to keep replacing the ink cartridges). I'm going to assume you tried this, but go ahead and run a few cleaning cycles on the printer, and see what happens.
Jul 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
337 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
